Audio-Technica ATH-M70x Headphones
Audio-Technica ATH-M70X Headphones
Audio-Technica announced their top-of-the-line, closed-back M-Series ATH-M70x Professional Monitor Headphones, which are tuned to accurately reproduce extreme low and high frequencies while maintaining perfect balance with exceptional clarity and detail. Designed specifically to bring out added detail in the mix, the ATH-M70x headphones feature proprietary 45 mm large-aperture drivers with rare earth magnets and copper-clad aluminum wire voice coils and are tuned to accurately reproduce extreme low and high frequencies (5 to 40,000 Hz) while maintaining perfect balance. Featuring rugged, metal design, they are ideal for studio mixing and tracking, FOH, DJ use, personal listening, mastering, post production and audio forensics.
Crafted for lasting durability with a collapsible, space-saving design, these flagship headphones are equipped with 90° swiveling earcups for easy, one-ear monitoring. Maximum power input is 2,000 mW, meaning very low distortion at even high volumes. Professional-grade earpads and headband provide excellent durability and comfort, and detach for easy replacement. The headphones’ circumaural design contours around the ears for excellent sound isolation in loud environments. They come standard with three interchangeable cables (1.2 m – 3.0 m coiled cable, 3.0 m straight cable and 1.2 m straight cable) and a hard carrying case.
Critically acclaimed M-Series professional monitor headphones deliver accurate audio and outstanding comfort, perfect for long sessions in the studio and on the go. Contoured earcups seal tight for excellent sound isolation, with minimal bleed. And the pro-grade materials are durable, yet comfortable.
Price and Availability
The Audio-Technica ATH-M70x Professional Monitor Headphones will be available from January 2015 for $419.
Specifications:
  • Type: Closed-back dynamic
  • Driver Diameter: 45 mm
  • Magnet: Neodymium
  • Voice Coil: CCAW (Copper-clad aluminum wire)
  • Frequency Response: 5 – 40,000 Hz
  • Maximum Input Power: 2,000 mW at 1 kHz
  • Sensitivity: 97 dB
  • Impedance: 35 ohms
  • Weight: 280 g (9.9 oz), without cable and connector
  • Cable: Interchangeable cables: detachable 1.2 m – 3.0 m (3.9′ – 9.8′) coiled cable, detachable 3.0 m (9.8′) straight cable and detachable 1.2 m (3.9′) straight cable
  • Accessories Included: Carrying case, 6.3 mm (1/4″) screw-on adapter
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
