Audio-Technica ATH-ANC700BT QuietPoint Wireless Headphones Battle Bose
Audio-Technica ATH-ANC700BT QuietPoint over-ear wireless active noise-cancelling headphones (gray)
Over-ear wireless active noise-cancelling (ANC) headphones with 25 hour battery life
Audio-Technica announced a competitor to the Bose QuietComfort 35 over-ear wireless active noise-cancelling headphones that not only cost $150 less, but have a 25% longer lasting battery. The full model name is quite a mouthful called the ATH-ANC700BT QuietPoint over-ear wireless active noise-cancelling (ANC) headphones. Newly developed ANC technology operates in a wider frequency range in the low through midrange frequencies than typical ANC designs, for a significant advancement in noise-cancelling performance and audio quality. The ATH-ANC700BT’s ANC microphones are mounted in a location where, unlike typical ANC headphones, they don’t unintentionally pick up some of the generated noise-cancelling signal, which yields improved noise reduction performance.
The ATH-ANC700BT features a new, intuitive touch and swipe control system for answering calls and controlling volume and playback. The ATH-ANC700BT employs large 40 mm drivers for impactful Hi-Res Audio frequency response from 5 Hz – 40,000 Hz when connected with the included 3.5 mm cable. The ATH-ANC700BT provides up to 25 hours of battery life in ANC and Bluetooth mode and can also be used in wired mode.
Features
  • QuietPoint active noise-cancelling technology powered by a proprietary four-microphone multi-feedback system greatly reduces environmental noise
  • Bluetooth wireless technology with touch and swipe controls built into the earcup for answering/ending calls, controlling music & video playback and adjusting volume on connected devices
  • 40 mm drivers deliver high-fidelity audio reproduction
  • Included 1.2 m (3.9′) cable with 3.5 mm (1/8″) stereo mini-plug provides a wired connection for when wireless operation is prohibited (e.g., in airplanes or hospitals), when battery power is low, or when Hi-Res Audio is desired
  • Foldable design makes headphones ideal for travel
  • On a full charge, internal battery provides up to 25 hours of continuous use of Bluetooth wireless and noise-cancelling technology, and up to 1,000 hours on standby
  • Includes 30 cm (1′) USB charging cable and a soft carrying case
Price and Availability
The Audio-Technica ATH-ANC700BT will be available March 2018 for $199 in black (ATH-ANC700BTBK) or gray (ATH-ANC700BTGY).
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
