Audio-Technica ATH-ADX3000 Open-Back Headphones: Flagship Performance for Half Price
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
Audio-Technica ATH-ADX3000 Open-back Headphones
Audio-Technica receives a lot of attention for its extensive lineup of phono cartridges and affordable turntables, but where the Japanese manufacturer wants you to divert your attention in 2024 and beyond is its growing lineup of high-end headphones. Having already proven that it can build one of the most expensive headphone amplifiers ever offered and some rather expensive dynamic headphones including the $2,000 AT-ADX5000, they have introduced the ATH-ADX3000 Open-Air (aka Open Back) Dynamic Headphones for $999.99 USD.
The ATH-ADX3000 features an open-back design that supports unrestricted airflow for the diaphragm contributing to realistic soundstage and imaging, without using added dampening material or acoustic aids.
The ATH-ADX3000’s full-range driver is designed by Audio-Technica and manufactured and hand-assembled in their Machida, Japan factory. The driver utilizes the same technology as the company’s acclaimed flagship ATH-ADX5000 headphones.
Another design implementation is Audio-Technica’s exclusive Core Mount Technology. This positions the driver’s voice coil in the middle of its housing so that the acoustic space is balanced in both the front and the back of the driver.
Audio-Technica TH-ADX3000 Headphones Driver Exposed
From Audio-Technica lead engineer Hiromichi Ozawa: “Our engineers worked hard to achieve a frequency response that is not easy to obtain by using only natural airflow. Our expertise in driver technology influenced our approach to open-back headphones, and enabled us to ensure that the driver diaphragm moves with the purest motion possible.”
The ATH-ADX3000 employs a 58 mm tungsten-coated diaphragm, pure iron magnetic circuit, voice coil, and aluminum housing which is combined in a single integrated driver unit. The diaphragm is lightweight and responsive, and the pure iron magnet enables improved dynamic range and high efficiency.
All combined, Audio-Technica’s approach is designed to support a structure that provides clarity and stereo imaging, with articulate bass, smooth midrange, and detailed, extended high frequencies. A honeycomb-punched housing design blocks side ventilation to prevent undesirable air pressure loss.
To support all-day wearing comfort the ATH-ADX3000 is light weight of only 280 grams. A  detachable 3.0 m (9.8-foot) cable with A2DC connectors and a robust aluminum storage case make use and transport easy.
Comparison
Audio-Technica ATH-ADX3000 (Left) and ATH-ADX5000 (Right)
ATH-ADX3000ATH-ADX5000
Price$999$1999
Headphone TypeOpen Air (aka Open Back)Open Air (aka Open Back)
Driver58 mm, Dynamic58 mm, Dynamic
Frequency Response5 to 45,000 Hz5 – 50,000 Hz
Maximum Input Power700 mW1,000 mw
Sensitivity98 dB/mW100 dB/mW
Impedance50 ohms420 ohms
ConnectorA2DC connector jack6.3 mm (1/4″) gold-plated stereo plug
Included AccessoriesDetachable cable (3.0 m (9.8’) / 6.3 mm (1/4”) gold-plated stereo plug)
Hard shell carry case
Detachable 3.0 m (9.8′) cable with A2DC connectors
Optional AccessoriesReplacement earpads, AT-B1XA/3.0 balanced cableHard shell carrying case
Weight257 g (9.1 oz)
without cable
270 g (9.5 oz)
without cable
Audio-Technica ATH-ADX3000 Headphones in  Travel case
The Bottom Line
Utilizing the same driver technology and open-back form factor of the previously released top-of-line ATH-ADX5000, the ATH-ADX3000 is designed to deliver impressive performance, wearing comfort, and provides a hard case for $1,000 less.
Of course, there are some specification differences between the two, but are they enough to make a buying decision difference?
Other headphones in the ATH-ADX3000’s price category include the recently released Shanling HW600 and other models such as the HiFiMAN Arya Organic and Audeze LCD-X.
The ATH-ADX3000 are also priced less than the Sennheiser/Drop HD8xx which have proven to be somewhat controversial.
Price & Availability
The Audio-Technica ATH-ADX3000 Open-Air Dynamic Headphones are available at a suggested U.S., retail price of $999.
For more information: audio-technica.com
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
