Audio-Technica Introduces AT-PEQ30 Phono Equalizer
Although called a phono equalizer in reference to the RIAA curve, this $229 phono preamp is designed to improve the sound quality of most turntables.
Audio-Technica AT-PEQ30 Phono Equalizer
High-Performance Phono Stage
Audio-Technica today introduced the AT-PEQ30 phono equalizer for $229. The compact hi-fi component is a phono stage designed specifically to add a phono stage to a turntable setup or to upgrade a turntable’s built-in phono preamplifier. The AT-PEQ30 accommodates MM (moving magnet) and MC (moving coil) phono cartridges and delivers what the company emphasizes as “superlative sound quality.”
The Audio-Technica AT-PEQ30 offers a selectable MM and MC input with a fixed gain of 35 dB (MM) or 59 dB (MC). Its input impedance is 47 kiloohms for MM and 120 ohms for MC, for compatibility with a wide range of phono cartridges. The AT-PEQ30 delivers a 250 mV line-level output for both MM and MC cartridges.
Audio-Technica AT-PEQ30 Phono Equalizer Front and Back Views
The AT-PEQ30 is built from premium-quality precision components, with a machined aluminum front panel, gold-plated input and output connectors and other refinements. Its FET inputs ensure low noise and precise RIAA equalization with a smooth, accurate tonal balance from 20 to 20,000 Hz. Measuring just 1.9 inches high by 7.8 inches wide by 4.9 inches deep for easy installation in any system, the AT-PEQ30’s all-metal construction provides superior isolation from outside electronic and radio frequency interference (EMI and RFI).
“Our new AT-PEQ30 is ideal for users who need a great-sounding phono stage for use with a turntable that doesn’t have a built-in phono preamp. It’s also a high-value solution for listeners who want to upgrade from their turntable’s built-in phono preamp and enjoy improved sound quality from their record collections.”
Bob Peet, Audio-Technica US Marketing Manager
Features
  • Selectable MM and MC input with fixed gain and impedance allows for compatibility with a wide range of moving magnet and moving coil cartridges
  • High-quality FET inputs ensure a low-noise signal when incorporated with a negative feedback-type phono equalizer circuit
  • Precision components provide an excellent RIAA response for best-in-class performance
  • The all metal construction enclosure provides superior isolation from radio and electronic noise interference
  • The machined aluminum front panel and gold-plated input/output RCA connectors are examples of the high-grade material used throughout
Specifications
Input ImpedanceMM type: 47 kiloohms
MC type: 120 ohms
Input SensitivityMM type: 4.5 mV
MC type: 0.28 mV
Rated output MM type: 250 mV
MC type: 250 mV
GainMM type: 35 dB
MC type: 59 dB
Signal-to-Noise RatioMM type: 100 dB
MC type: 74 dB
RIAA Deviation(20 to 20,000 Hz) MM type: ±0.5 dB
(20 to 20,000 Hz) MC type: ±0.5 dB
Power SupplyDC 15 V, 1.2 A
Power Consumption2.5 W
Dimensions47 mm (1.85″) H x
197.5 mm (7.78″) W x
125.5 mm (4.94″) D
(excluding protrusions)
Weight890 g (31.4 oz)
Accessories IncludedAC adapter
Price & Availability
The Audio-Technica AT-PEQ30 phono equalizer is available now for $229.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
