Earbuds & In-Ear Headphones
Audeze Euclid Closed-Back IEMs Raise the Bar and Price for Headphone Users
Audeze’s first closed-back in-ear headphone targets audiophiles and pro audio users that can afford its $1,299 price tag.
Pair of Audeze Euclid Earphones on chrome
Audeze have announced the release of a new high-end closed-back in-ear earphone called the Euclid for $1,299. The earphone features custom built 18mm planar magnetic drivers, precision milled aluminum housing and both wired and Bluetooth connectivity.
Audeze Euclid Closed-back Earphones
The Euclid is Audeze’s fifth earphone; and expands on the existing LCDi4, LCDi3, iSine 20 and iSine 10. In terms of pricing, it fits between the LCDi4 ($2495) and the stellar LCDi3 we recently reviewed for $899. Although it is not a replacement for any model in the existing lineup, it was created in response to direct feedback from Audeze’s distributors in Asia.
The major departure with the Audeze Euclid is its closed back design, which stops other people from hearing what you are listening to. Both the iSine and LCD series earphones are uniquely open back planar magnetic designs that have pushed the performance envelope in the category.
Audeze Euclid In-ear Headphone around ear
The Audeze Euclid addresses some of the concerns from previous models. Most notably, the earhooks are dropped. The Euclid fits in your ear like normal earbuds allowing the wire to wrap around your ear. They’re a little smaller than the iSine (0.5mm vs 0.7mm) and should fit inside most ears more easily. And they’re more durable, made of aluminum instead of plastic.
Euclid is designed for audiophiles and pro audio users seeking a high-end in-ear headphone.
Sound Quality
As for sound quality, Audeze claims Euclid produces zero audible distortion with enhanced clarity and accuracy in sound reproduction. Further adding, “customers should experience a wider, more immersive sound stage.”
“Euclid delivers heightened detail retrieval and sonic accuracy with a soundstage and dynamic range so robust you’ll forget you’re listening to a closed-back in-ear. The miniaturized 18mm single planar magnetic driver has no crossovers, resulting in superior cohesion across the entire frequency spectrum. Euclid boasts an incredible 105 dB/mW efficiency and a max SPL well over 120dB, giving it the highest dynamic range of any in-ear in its size category.”
Sankar Thiagasamudram, Founder & CEO at Audeze
Audeze Euclid In-ear Headphone Exploded
Features
  • Custom built 18mm Planar Magnetic Drivers
  • Precision milled closed-back aluminum housing
  • Wired 3.5mm or Bluetooth (aptX/aptX HD) connection
  • Memory wire for universal comfort and fit
  • MMCX universal cable connectors for easy customization
  • Fluxor Magnet design for 110 db/MW efficiency
  • Fazor wave guides
  • Uniforce Thin film diaphragm.
  • Memory wire cable
Price & Availability
Audeze Euclid is available today, February 5, 2021 for $1299 at Audeze.com.
Single Audeze Euclid Closed-back In-ear Headphone
Specifications
StyleIn-ear earphones
Transducer typePlanar Magnetic
Magnetic structureFluxor™ magnet array
Magnet typeNeodymium N50
Diaphragm typeUltra-thin Uniforce™
Transducer size18mm
Maximum SPL>120dB
Frequency response10Hz – 50kHz
THD<0.1% (1 kHz, 1mW)
ConnectorMMCX
Ear TipsS/M/L (Silicone)
Battery type (BT Cable)Lithium-polymer
Wireless ConnectionBluetooth (SBC, AAC, AptX, Aptx HD)
Wired Connection3.5mm analog audio
Weight50g
In the Box
Audeze Euclid box contents
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
Over-Ear Headphones
For under $600, the DT 1770 Pro MKII closed-back studio headphones are a more refined and textured update of a classic studio can.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Over-Ear Headphones
Not inexpensive at $5,995, but the Audeze CRBN2 Electrostatic Headphones might be one of the best ever made.
