Get SLAM with Audeze’s New CRBN2 Electrostatic Headphones: CanJam SoCal 2024
At $5,995, Audeze’s flagship CRBN2 Electrostatic Headphones feature proprietary SLAM acoustic techhnology for enhanced bass response.
Audeze CRBN2 Electrostatic Headphones (2024 model)
Audeze today has announced the 2nd generation CRBN electrostatic headphone named CRBN2. At $5,995, they arrive as Audeze’s new flagship headphone — the best they’ve ever made.
What’s New?
There are two main differences. The biggest advancement is something Audeze invented called Symmetric Linear Acoustic Modulator (SLAM). It’s visually the gold layer sandwiched between the ear pads and housing, but internally functions as a venting system that optimizes air pressure distribution across the driver for better sound. The second change involves the secret sauce in its carbon nanotube diaphragm. Audeze is calling it a 2nd generation carbon-nanotube electrostatic driver, but beyond that we haven’t learned what makes it better.
Audeze CRBN (left) vs. CRBN2 (right) Electrostatic Headphones Back
“With CRBN2, we’ve pushed the boundaries of electrostatic technology even further, introducing our new SLAM system to deliver the most lifelike bass and transparency ever achieved in an electrostatic headphone. Our goal was to create an immersive experience that truly brings music to life leveraging the audio innovations Audeze is known for,” said Audeze CEO Sankar Thiagasamudram
Audeze CRBN2 Open-back Electrostatic Headphones
What is SLAM?
Symmetric Linear Acoustic Modulator (SLAM) is Audeze’s patent-pending acoustic system tuned to enhance selected low frequencies while improving phase response without adding distortion. It works by optimizing air pressure distribution across the driver in a very specific way that only affects low frequencies.
To put simply, SLAM improves bass performance, which is a common issue with electrostatic headphone designs.
In a pre-production demo at Audeze HQ, Sankar showed me diagrams of different SLAM prototypes used in development. The prototypes appear as a flat disc etched with a grooved channel pattern. Apparently different pattern etchings affect sonics until a final design was chosen.
Ultimately, Audeze claims SLAM gives the CRBN2 a bass response that is both physical and lifelike, unmatched by any other electrostatic headphone on the market.
Tip: Audeze’s proprietary SLAM technology is not specific to electrostatic headphones, and could make its way into Audeze’s planar magnetic headphones in the future.
Problem Solved
In addition, SLAM technology also alleviates a common annoyance among any electrostatic headphone — static noise. That can happen when electrostatic headphones are put on/off which creates a pressure wave that forces the driver against the stator (frame). With SLAM, the air pressure wave is vented through the SLAM channels, severely mitigating this issue. You can still cause it with extreme force, but on the whole, SLAM reduces this issue greatly, and should help safeguard the drivers against accidental damage.
Build Quality
Audeze CRBN2 Open-back Electrostatic Headphone Side Closeup
Each CRBN2 headphone is hand-assembled and tested in California by electrostatic specialists, ensuring the highest standards of quality. The design uses premium materials, including sumptuous leather earpads and a suspension headband strap, to provide luxurious comfort for hours of listening.
Weighing only 480 grams and free of heavy magnets, the electrostatic design ensures long-term comfort and wearability. Additionally, CRBN2 is compatible with all 580-volt bias electrostatic amplifiers, offering versatility to audio enthusiasts who already have an electrostatic amplifier at home.
Background
CRBN2 builds on Audeze’s history of innovation in audio technology. The CRBN line originated from a project with Prof. Mark S. Cohen, Ph.D., and his team at the UCLA School of Medicine to create headphones for use in MRI machines. The powerful magnetic fields in MRI machines required a unique, non-ferrous driver design, leading to the development of the carbon-nanotube film-based electrostatic driver. This groundbreaking technology has been adapted and refined in CRBN2 in order to deliver one of the most accurate and immersive audio experiences available today.
Requirements
Don’t expect to plug CRBN2 into your phone or DAP. CRBN2 requires a specially designed amplifier with an electrostatic output using a 580VDC bias, commonly known as “Stax Pro Bias.” It is compatible with a variety of amplifiers on the market, ensuring that users can enjoy the CRBN2’s superior sound quality with their existing systems.
Specifications Compared
Audeze CRBN vs. CRBN2 Electrostatic Headphones Angle
CRBN (2021)CRBN2 (2024)
MSRP$4,500$5,999
StyleOver-ear, open-backOver-ear, open-back
Transducer typePush-pull electrostaticPush-pull electrostatic
Functional bias voltage580 VDC Stax Pro Bias580 VDC Stax Pro Bias
Electrostatic capacitance100 pF (including cable)100 pF (including cable)
Diaphragm typeUltra-thin custom carbon nanotube2nd generation Ultra-thin custom carbon nanotube
Diaphragm managementSLAM Technology for earcup pressure relief and bass enhancement
Transducer size120mm x 90mm120mm x 90mm
Frequency response20Hz – 40kHz10Hz – 40kHz
Maximum SPL>120dB>120dB
THD<0.1% @ 90dB<0.1% @ 90dB
Attached cable2.5m OCC monocrystal copper, 5-pin Pro Bias2.5m OCC monocrystal copper, 5-pin Pro Bias
HousingMagnesium, stainless steel and polymer acetateMagnesium, stainless steel and polymer acetate
Earpad materialPremium leatherPremium leather
HeadbandCarbon fiber and premium leatherCarbon fiber and premium leather
Weight470 grams480 grams
Audeze CRBN (left) vs. CRBN2 (right) Electrostatic Headphones Side
Eksonic Aeras Electrostatic Amplifier atop Bricasti Design M3 DAC
Listening demo headphone rig included Eksonic Aeras Amplifier ($7,000) atop Bricasti Design M3 DAC ($7,000) at Audeze HQ in Santa Ana, CA.
Hands-On Listening
At Audeze HQ, I was offered a brief demo where I got to compare the original CRBN with a pre-production version of CRBN2. If the final version is what I heard, Audeze really have found a way to make the original even better — and the difference was not subtle. I’m fairly sure I was hearing layers of bass and details that I don’t even think the mastering engineer knew were there. The original CRBN was already stellar, but CRBN2 takes things to a whole new level. Simply phenomenal!
A mere $20,000 (all-in) to own the full system as tested.
Price & Availability
Audeze CRBN2 is available now for $5,995 on the Audeze website.
Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
Headphones
An affordable electrostatic headphone? The STAX SR-X1 makes that a real possibility for those who have always wanted to experience what makes them unique.
Over-Ear Headphones
HiFiMAN Arya Unveiled open-back headphones feature exposed planar magnetic drivers and an all-new sound. Find out how it compares to the prior Organic and...
Over-Ear Headphones
Not inexpensive at $5,995, but the Audeze CRBN2 Electrostatic Headphones might be one of the best ever made.
At $1,300, is the STAX SRM-400S capable of driving some of the best headphones in the world?
Earbuds & In-Ear Headphones
Smaller, lighter, and more affordable than the flagship Empyrean II, the $2,000 Meze Audio Poet have planar magnetic fans rather excited.
At $1,400, the fourth-generation Arya Unveiled features a removable “Magnetic Veil” back panel and Stealth Magnet Technology.
Headphones
Not only do the new Grado Signature S950 feature an improved headband, gorgeous ear cups, and a brand new 52mm driver...but they finally have...
