Atlantic Technology WA-60 Can Replace Audio Cables
Atlantic Technology WA-60 Wireless Audio System - Front View
Atlantic Technology has introduced the WA-60 WA-60 Wireless Audio Transmitter/Receiver System, which eliminates the need to string unsightly audio cables across the room. With low-frequency response down to 10 Hz, it is ideal for subwoofers. It can also be used to connect receivers, computers, or any line-level audio device across a room or from one end of the house to the other, with a range of up to 70 feet, or 150 feet line-of-sight.
The $200 Atlantic Technology WA-60 improves upon the prior WA-50 wireless transmitter with deeper low frequency response for subwoofer applications, longer range, and more channels.
Atlantic Technology WA-60 Wireless Audio System - Rear View
The Atlantic Technology WA-60 is a simple-to-use, inconspicuous transmitter-receiver system with full-range CD-quality sound. There is no interference or time delay, and it provides easy plug-and-play functionality — no software needed. Each receiver/transmitter pair can use one of four separate carrier frequencies to allow up to four WA-60 systems to operate in the same space without signal overlap.
Each WA-60 system broadcasts a full-range, 10 to 20,000 Hz stereo audio signal anywhere across multiple rooms, wirelessly, and while maintaining an impressive 93 dB signal-to-noise ratio. Additional applications include sharing computer-based audio with an AV receiver or sharing a main system’s sources with secondary rooms.
Specifications
  • Frequency: 10 Hz to 20kHz, great for subwoofers
  • Range: Line of sight: 130-150′ / Obstructed: 70′
  • Power:+5VDC (USB)
  • Audio In/Out: Stereo RCA
  • RF Band: 2.4GHz
  • Available Wireless Channels: 4
  • SNR: 93 dB
  • Dimensions (with antenna): 3-3⁄4″ W x 3-7∕8″ H x 4″ D (95mm x 98mm x 102mm)
  • Weight: (each, unpacked) 3.5 oz / 0.1kg
Price and Availability
The Atlantic Technology WA-60 Wireless Audio System (receiver/transmitter pair) is now available for $199 and extra receivers are $89 each.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
