Atlantic Technology WA-50 Wireless Audio Transmitter
Atlantic Technology has introduced its WA-50 Wireless Audio System, which can transmit a full-range stereo signal wirelessly up to 150 feet, or 300 feet line-of-sight, and with no time delay or interference. The WA-50 system can accommodate three zones and eliminates the need for long runs of RCA cable for powered subwoofers or remote amplified speaker systems.
The Atlantic Technology WA-50 wireless audio system is incredibly easy to set up and use. Up to three WA-50 transmitters and an unlimited number of receivers can be used in a system. Simply connect the WA-50 transmitter to the desired RCA audio outputs, and the WA-50 receiver to the RCA line inputs of a powered subwoofer or powered speaker system. Both the transmitter and receiver have a three-position switch that assigns each pairing to either Zone 1, Zone 2, or Zone 3.
The WA-50 can also be connected to your PC or Macintosh using a supplied USB cable interface. This allows the WA-50 to transmit music from the computer to your high-end audio system or to a portable audio system by the pool for parties.
The Atlantic Technology WA-50 Wireless Audio System, consisting of a transmitter, receiver, UDB Cable, and RCA input and output cables, is now available for a suggested retail price of $199, with additional WA-50 receivers and output cables available for $89 each.
Atlantic Technology WA-50-R Wireless Audio Receiver
Atlantic Technology WA-50 Specifications
  • Frequency Response: 20-20kHz, +/-1dB
  • Signal to noise Ratio: 93 dB
  • Max time delay: 10ms
  • Range (indoors): 50 Meters
  • Range (line of sight): 100 Meters
  • Zones: 3
  • Dimensions: 1-1/2″ x 3-1/4″ x 3/4″ (38 x 83 x 19 mm)
  • MSRP:
    • $199 for transmitter & receiver
    • $89 extra receiver
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
