Atlantic Technology Announces Nexa 1 Portable Music System
At only $199, Atlantic Technology’s first portable Bluetooth speaker sports a robust 60-watt amplifier and 15 hours of battery life.
Atlantic Technology Nexa 1 portable Bluetooth Speaker Lifestyle
Atlantic Technology has announced its first portable music system, the Nexa 1. This portable speaker incorporates a refined industrial design which is intended to balance form and function for music lovers looking for improved sound quality on the go.
Nexa 1 Core Features
Atlantic Technology Nexa 1 portable Bluetooth Speaker No Grille
To deliver the desired sound quality, the Nexa 1 includes two 2.5-inch aluminum full-range drivers and a rear oval passive radiator supported by a 60-watt amplifier.
For use in any environment, the Nexa 1 has an IPX5 rating. This means that it is water and dust-resistant for both indoor and outdoor use. The touch-sensitive film that covers the Nexa 1’s status LEDs and top-panel controls is waterproof which allows continued operation during different weather conditions.
Atlantic Technology Nexa 1 portable Bluetooth Speaker Top Panel Zoom
The provided LED indicators visually indicate operational status and sound effects. The top controls provide access to Play/Pause, Volume adjustment, and Track selection. A dedicated Hang-up button allows the user to end phone calls (the Nexa 1 has a built-in microphone), while the Aux switch, phone assistant controls, and sound effect/mode switching options provide further flexibility.
The Nexa 1 is Bluetooth 5.3 compatible which provides easy streaming connection from compatible devices such as smartphones. The Nexa 1 supports one-touch TWS (True Wireless Stereo) pairing. This makes it easy to add a second Nexa 1—or any other compatible device.
Atlantic Technology Nexa 1 Portable Bluetooth Music System Front
In addition to Bluetooth, the Nexa 1 also provides a 3.5 mm digital audio input and a microSD card slot.
For added convenience, the Nexa 1 also provides a USB-C charging port which can not only charge the Nexa 1 but can also be used to charge an additional Nexus 1 if needed, with the Nexus 1 acting as a power bank. On a full charge, the Nexa 1 can play for up to 15 hours.
At 2.6 lbs, the Nexa 1 can be easily moved from room to room and is easily transportable when on the go.
Atlantic Technology Nexa 1 Portable Bluetooth Music System Front Angle
Specifications
Atlantic Technology Nexa 1 Portable Bluetooth Speaker by Pool
Price & Availability
The Atlantic Technology Nexa 1 is available for $199 at altantictechnology.com and from authorized dealers beginning May 2024.
1 Comment
1 Comment
  1. ORT
    May 1, 2024 at 2:39 pm
    That is one good looking BlooToof speaker!
    Norman ORTwell
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
In-depth review compares three of the best luxury portable Bluetooth speakers on the market from Brane, Soundboks and Devialet.
