Atlantic Technology IWTS-4, IWTS-7, IWTS-14 LCR-IP In-Wall Speakers
Atlantic Technology Delivers its First StreamNet-Enabled In-Wall Loudspeakers for NetStreams Whole House Protocol with Major Sound Quality Benefits
For consumers desiring in-wall loudspeakers all around the house, connecting those speakers using NetStreams StreamNet internet-protocol (IP) technology makes a lot of practical sense. This technology also creates an opportunity to significantly improve the performance, sound quality, and local acoustics of the loudspeakers. … “A completely digital signal stream means better sound quality and perfect uniformity, so what’s not to like?” says Atlantic Technology’s Peter Tribeman.
Atlantic Technology, a leading manufacturer home theater and architectural loudspeaker systems, today announced immediate deliveries of three StreamNet-enabled in-wall loudspeakers designed to use NetStreams whole-house internet-protocol (IP) technology. Remarkably, these loudspeakers take further advantage of IP technology for significantly improved audio performance, sound quality, and adaptability to local acoustic conditions.
These sonic improvements are made possible by using separate, individually-equalized power amplifiers for the tweeter and the woofer…a configuration known as active bi-amplification. It allows the speaker designer to use digital processing to create the ideal audio signal for each separate speaker driver, and to totally by-pass the use of conventional electrical crossover networks, which can be difficult to equalize and inefficient.
 Atlantic Technology IWTS-4 LCR-IP
“IP technology is a game changer for loudspeaker designers,” said Peter Tribeman, President, Atlantic Technology. “It’s like going from chemical photography to digital photography. By giving speaker designers the ability to deliver the optimal audio signal directly to each individual transducer, it opens up a world of new possibilities. The signal stream remains digital all the way from the recording studio through the NetStreams system, until it reaches our speakers. The end user enjoys every last bit of potential performance from our speakers.”
The new Atlantic Technology IWTS-4 LCR-IP, IWTS-7 LCR-IP and IWTS-14 LCR-IP loudspeakers are designed for home theater and music applications. They are based on three of the company’s most popular models, and each also includes a conventional crossover network for traditional installations. A rear-panel switch selects between the conventional speaker wire input connectors and the NetStreams Phoenix-style connector.
While the basic concept of StreamNet-enabled speakers is relatively straightforward, Atlantic Technology’s long history of in-wall innovation provides several unique design advantages that make them especially well-suited to NetStreams’ applications. Atlantic Technology in-wall speakers include sophisticated adjustments to optimize for varying room absorptive characteristics, Boundary Compensation switches to tailor their frequency response depending on how close to an adjacent wall they’re mounted, and Atlantic’s exclusive Directional Vector Control (DVC) to electronically direct the sound up or down from the speaker — without having to resort to unsophisticated mechanical “pivoting tweeters.” Only Atlantic speakers provide the end-user with this comprehensive array of acoustic optimization controls, and now they have all been recreated in the StreamNet-enabled mode. Atlantic and NetStreams engineers worked hand-in-hand for months to replicate every single one of the Atlantic equalization and adjustment curves digitally in the NetStreams electronics.
Another benefit to the NetStreams mode is that the signal completely avoids all the resistors, capacitors, and inductors in the passive crossover, so there is no insertion loss. As a result, the system will play as much as 5dB louder. This means that the NetStreams’ 50-watt amplifiers are the functional equivalent of conventional 160-watt amplifiers. The whole system plays louder, cleaner, with less distortion, and perfect uniformity from one speaker to the next.
The Atlantic Technology IWTS-4 LCR-IP, IWTS-7 LCR-IP and IWTS-14 LCR-IP are now shipping to dealers, and they have suggested retail prices, with grilles and frames, of $250, $385, and $515 each respectively. To help installers control costs, the grilles and frames for the two top models can be purchased separately in advance for $60 and $65 each. This allows the custom installation contractor to install the frames, but delay purchasing the more expensive components until near the end of the job.
IWTS-4 LCR IP IWTS-7 LCR IP IWTS-14 LCR IP
Type 2-way 2-way 2-1/2-way
Woofer(s) 6 1/2″ (165 mm) GLH 6-1/2″ (165 mm) GLH 2 6-1/2″ (165 mm) GLH
Tweeter 1″ Soft Dome LRT™ 1″ Soft Dome LRT™ 1″ Soft Dome LRT™
Frequency Response 57HZ – 20kHz, +/- 3dB 53HZ – 20kHz, +/- 3dB 47HZ – 20kHz, +/- 3dB
Nominal Impedance 6 -ohm 6 -ohm 6 -ohm
Crossover Frequency 2400Hz, 3rd order 2100 kHz 800 Hz / 2.1 kHz
Sensitivity 88 dB 87 dB 87 dB
Recommended Power 10 – 100 watts 10 – 100 watts 10 – 125 watts
Dimensions with Frame (WxHxD) 8-3/4 x 12-1/8 x 3-3/4″ (223 x 308 x 96 mm) 9-1/4 x 17-3/4 x 3-7/8″ (236 x 449 x 100 mm) 10-13/16 x 19 x 3-7/8″ (274 x 484 x 100mm)
Cutout Dimensions (WxHxD) 7-5/8 x 11″ (194 x 280mm) 8-1/8 x 16-1/2″ (207 x 420mm) 9-5/8 x 17-7/8″ (245 x 454mm)
Grille/Frame Model No. GFR-52 GFR-525
Speaker MSRP $250 $325 $450
Grille & Frame MSRP Included $60 $65
Total MSRP $250 $385 $515
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
