Atlantic Technology ICTS and TLC In-Ceiling Speakers Announced
Atlantic Technology introduced five new stealthy ceiling mounted loudspeakers for home theater and whole house distributed audio.
The Atlantic Technology ICTS-6HT (pictured above) is an in-ceiling home theater speaker designed for use as the front left, center and right channels of a home theater system. The 6-1/2-inch polypropylene woofer is mounted at a 15 degree angle so in can direct midrange and vocals toward the listener for improved imaging and intelligibility. To further enhance imaging, the tweeter can be pivoted up to 30 degrees so the full frequency range of the front channels remains perfectly focused. The speakers have built-in tweeter level controls and a woofer-level/boundary compensation adjustment.
Atlantic Technology TLC-8.2 In-Ceiling SpeakersAtlantic Technology TLC-8.3 In-Ceiling Speakers
Atlantic Technology is also introducing four new Trim-Look Ceiling speakers with thin magnetically attached grilles that are nearly invisible to the casual observer. These highly efficient speakers offer exceptional sound quality for music and home theater applications. The top two models, TLC-6.3 and TLC-8.3 (pictured right), are Tri-Mode speakers with dual-voice-coil woofers and two pivoting tweeters. They have separate left- and right-channel input terminals, input jumpers and a built-in bipole/dipole switch. These allow the speaker to be used for mono, single-point stereo, or as a surround speaker. The two base models, TLC-6.2 and TLC-8.2 (pictured left), are conventional, single-channel 6-1/2- and 8-inch two-way speakers with 1-inch soft dome tweeters that can pivot 30 degrees for optimal imaging.
Atlantic Technology TLC Dipole Switch
TLC Dipole Switch
Atlantic Technology TLC Connectors and Jumpers
Price and Availability
ICTS-6HT → $400 each
TLC-6.3 → $325 each
TLC-8.3 → $450 each
TLC-6.2 → $250 each
TLC-8.2 → $325 each
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
