Atlantic Technology Releases Flagship Passive Sound Bar, Model FS5
Atlantic Technology FS5 Front Stage Loudspeaker
Atlantic Technology just started shipping their new flagship three-channel passive sound bar called the FS5 Front Stage Loudspeaker system. The company claims their $1200 sound bar offers exceptional sound quality in a size and profile ideal for flat-screen TVs measuring 50 inches and up. But you’ll need a receiver or amplifier to use with it to make it work.
The Atlantic Technology FS5 is a true, no-excuses high-fidelity loudspeaker system that contains all three front-channel (LCR) theater speakers in a single enclosure. Its attractive piano-gloss cabinet is 50 inches wide but only 3 inches deep so it can be wall-mounted using built-in keyhole brackets, placed on a shelf or used with Atlantic’s special Shelf-2405, which provides a shelf attached directly to the flat screen TV itself.
Atlantic Technology FS5 Sound Bar
The FS5 draws upon Atlantic Technology’s long expertise in home theater speaker acoustics. Each of the three independent speaker systems contains two 4.5-inch CPP woofers, an ultra-wide dispersion 3/4-inch silk dome tweeter, and an audiophile-grade crossover network. The tweeters are mounted high between the woofers in a low-diffraction baffle to ensure dialog intelligibility. The company claims sound is smooth, vibrant and spacious, with the unmistakable detail and effortless quality typical of the company’s loudspeakers. With two woofers for each channel, bass response extends down to 80Hz, which more than deep enough that any accompanying subwoofer to be totally non-localizable.
The drivers of the FS5 (and also FS3, LCR2 and LCR3) are mounted in a dense resonant-free mounting plate that sits proud of the speaker baf e. The result is that the drivers “see” a smooth local acoustic environment, so none of their sound diffracts off the blunt inner surface of the grille frame, the way it does on a conventional speaker. Atlantic Technology says this helps the FS5 sound clear and unfettered, for maximum clarity and intelligibility.
Price and Availability
The Atlantic Technology FS5 Front Stage Loudspeaker is now available with an MSRP of $1,199.
Specifications
  • Type: Sealed-box, 2-way front stage Left, Center, Right
  • Drivers: Woofers: (2) 41⁄2 ̋ Composite Polypropylene/Paper (per channel)
  • Tweeters: (1) 3⁄4 ̋ silk dome tweeter (per channel)
  • Frequency Response: 80Hz – 20kHz (± 3dB)
  • Nominal Impedance: 6 Ohms
  • Crossover frequency: 3.5kHz
  • Sensitivity: 89dB
  • Recommended Amplifier Power: 10 – 140 Watts
  • Dimensions: 50″ x 61∕16″ x 3″ (1270mm x 170mm x 76mm) w/grille
  • Weight: (each, unpacked) 18 lbs; 8.16kg
  • Finishes Available: Gloss Black
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
