Atlantic Technology FS-7.1 / SB-900 Home Theater Speaker System
Atlantic Technology introduced the FS-7.1 seven-channel soundbar home theater speaker with SB-900 subwoofer to enjoy 7.1-channel surround sound without the clutter. The new soundbar is a significantly redesigned version their FS-7.0 seven-channel home theater sound bar with a new look, improved acoustics, and higher performance. Like its predecessor, the new Atlantic Technology FS-7.1 has seven speaker-level inputs allowing for simple and direct connection to any seven-channel home theater receiver.
While the new FS-7.1 looks quite different with its redesigned enclosure and grilles, the major improvements are under the hood. Now the surround drivers are angled forward for improved surround-sound effects in rooms even when the listening room doesn't have nearby side walls. The company also revoiced the crossover for smoother, more accurate sound and improved power-handling capabilities. It also boasts both keyhole and threaded inserts for easy mounting.
Atlantic Technology FS-7.1 Surround Sound Illustration
Like its predecessor, the FS-7.1 works best with a subwoofer, and Atlantic Technology upgraded that too. The new 125-watt SB-900 subwoofer has a more powerful amplifier than the 100-watt SB-800, and an improved limiter that gives it the ability to play louder. Together, the FS-7.1 and SB-900 deliver a simple and highly capable two-box solution for outstanding 7-channel home theater.
Price and Availability
The Atlantic Technology FS-7.1 soundbar is available now for $950 and the SB-900 costs another $350.
Atlantic Technology FS-7.1 Soundbar - Front
Atlantic Technology FS-7.1 Soundbar – Front
Atlantic Technology FS-7.1 Soundbar - Back
Atlantic Technology FS-7.1 Soundbar – Back
Specifications
Model FS-7.1 SB-900
Type 7-Channel Soundbar Powered Subwoofer
Woofer (2) 4 x 6″ (102 x 153mm) dual voice coil 8″ (203mm) long-throw
Tweeter (3) 1″ (25mm) soft dome N/A
Surround (3) 3 1/4″ (83mm) dual voice coil N/A
Frequency Response 75Hz – 20kHz ±3dB 32-200Hz ±3dB
Nominal Impedance 8 Ohm N/A
Crossover Frequency 2.5 kHz 55-200Hz, variable; or bypass setting
Sensitivity / Peak Output 89 dB 103dB SPL into 2000 cubic feet
Recommended Amplifier Power / Amplifier Power-THD 10 — 125 Watts RMS 125 Watts RMS @< .5% THD
Dimensions w/ grilles (W x H x D) 43-1/2 x 5-1/2 x 5 1/4″
1105 x 140 x 134mm
11 x 13 x 13″
280 x 330 x 330mm
Weight (ea) 37bs; 17kg 28lbs; 12.7kg
See more about: Sound Bars, Speakers, Subwoofers, Speaker Bars, Home Theater
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
