Atlantic Technology FS-252 Wireless Bookshelf Speakers Have SKAA
Atlantic Technology FS-252 SKAA Wireless Active Bookshelf Speakers
Better than Wi-Fi Sound Quality
Atlantic Technology just released the FS-252 powered bookshelf speakers that feature SKAA wireless technology for receiving and transmitting high quality audio. Derived from the pro music industry, SKAA is a standard designed for audio creating a dedicated ecosystem that far surpasses Wi-Fi in terms of sound quality, distance, ease-of-use and reliability.
Atlantic Technology FS-252 Wireless Active Bookshelf Speakers Front View
Priced at $749 a pair, the FS-252 active 2-way stereo bookshelf speakers claim to offer a full and deep sound, ideal for music in one room or as multi-room sets around the home. For home theater use, they are acoustically matched to work in systems with Atlantic Technology Sound Bars and LCR speakers.
The FS-252 can be connected to a wide variety of analog media sources (CD players, TVs, etc) via various wired connections and wireless digital media sources equipped with Bluetooth or SKAA transmitters – a capability that sets them apart from other multi-room systems. A SKAA media source may be any product equipped with SKAA such as another FS-252 or any audio product with a SKAA transmitter/adapter added.  Small, low-cost SKAA digital transmitters, adapt any analog or digital audio device to affordably, quickly and easily add SKAA wireless capability.  This includes PC, MAC and NAS – and portable iOS, Android or Blackberry devices can be turned into a SKAA transmitter with adapters for USB-A, micro-USB, USB-C (coming soon), or iOS Lightning. Digital TOSLINK and coax S/PDIF plus stereo analog to SKAA transmitters are also available.
Benefits of SKAA Technology
Wi-Fi and Bluetooth were originally developed for data networking and phone use then later adapted to entertainment audio.  Music streaming is very demanding on Wi-Fi network bandwidth revealing many weaknesses including sound quality, interference, dropouts, variable latency or signal delay and limited signal range.  Also, their continuously variable high latency, creates A/V lip-sync issues making wireless speakers unsuitable for TV, film and video games.  Plus, Wi-Fi network set-up and connection processes include passwords and special router configurations that can make setting up and operating multiple home Wi-Fi audio devices complex, slow and clumsy.  While Bluetooth is easier to connect it has a more limited range than Wi-Fi, is also subject to interference and is incapable of multi-room operation.
The good news is that SKAA eliminates all issues of other wireless audio systems. SKAA is a new wireless standard purpose built from the ground up to work seamlessly in all Hi-Fi applications; whole house, home theater, portable, pro-audio and automotive. SKAA is a cousin of “PAW” or Pro Audio Wireless, proven for years in demanding live concert performances by pro musicians world-wide to reliably stream instruments and singers in perfect sync with high-quality sound pro musicians and audiences demand.
SKAA audio is always clear, full-frequency and with high dynamic range delivering sound quality comparable to wired systems.  It is perfect for movie and games eliminating lip-sync issues, with an un-perceivable 36 millisecond fixed low-latency signal that’s 4 to 5 times lower than Bluetooth’s variable 120-200 ms latency, and 50 to 80 times lower than Wi-Fi’s variable 2,000 to 3,000 ms latency. The variable latency creates a perceptible, out-of-sync audio shifting between multi-room Wi-Fi speakers while SKAA’s low 36 ms fixed latency delivers clear, unified multi-room audio with 0.04 ms precision between speakers.
SKAA delivers a robust signal up to a 150 foot range using the worldwide open 2.4 GHz band.  It’s reliable because of its patented Walking Frequency Diversity™ (or WFD) channel-hopping technology with error correction eliminating interference, clicks, pops or dropouts even in the noisiest RF environments common in tech-laden homes, apartments, businesses or even busy trade shows.
No special app, network, Wi-Fi set-up, passwords or pairing is needed to connect SKAA devices; just press one button to connect any SKAA speaker, receiver or headphone to whichever audio source you desire.
SKAA is an international wireless standard that ensures all products carrying the SKAA logo are 100% compatible across a growing number of products and brands.  A diverse eco-system is quickly emerging from Atlantic Technology and other companies that will allow consumers to easily create a variety of compatible home and portable wireless entertainment systems for inside and outside the home that are interference and hassle-free, without sonic compromise.
It’s easy to add optional plug-and-play SKAA transmitters to home and mobile devices turning any analog or digital audio device into a SKAA transmitter, able to simultaneously stream audio to other home SKAA speakers, headphones or receivers.
For SKAA transmitters used with the FS-252, a free optional App called SKAA cmd is available for iOS, Android, Mac and PC.  This gives a transmitter customizable multi-room operation such as setting up group control or selective muting of speakers around the home.
Features
The FS-252 includes a 25 watt-per-channel class-D amp optimized to the speakers in elegant high-gloss piano black, resonance-free MDF cabinets with component audio feet. Each has two long-throw 3.5-inch composite polypropylene drivers in an M-T-M, D’Appolito array with a .75-inch silk dome tweeter offset for great stereo imaging. Bottom firing four-inch passive radiators extend bass to create a surprisingly big sound from the small package.  Removable acoustically transparent cloth grilles give a finished look.
Atlantic Technology FS-252 Wireless Active Bookshelf Speakers Back View
The system’s “right channel” back panel includes all audio inputs and outputs, a master power on/off switch, a power cord receptacle and a jack for a single cable link to the “left” speaker unit.  A seven button IR remote which duplicates the five-button side mounted system control panel with LED indicators is included.
Any analog audio device can connect to the FS-252 through its RCA or 3.5 mm stereo inputs. Bluetooth with aptX™ and AAC is built-in to receive the highest quality music from mobile devices or home computers.  Unlike other multi-room audio systems on the market, the FS-252, can broadcast high-fidelity audio to multiple SKAA receivers from virtually any source be it analog or digital Bluetooth and SKAA.
The FS-252 is both a SKAA transmitter and receiver.  As a transmitter it can cast simultaneously to up to four additional SKAA systems, amps or headphones for single or multi-room use. Adding or switching between sources or transmitters is done with a click of a button on the speaker or the wireless remote with no cumbersome paring or Wi-Fi resets involved.
Atlantic Technology FS-252 Speaker Bottom View
Specifications
Cabinets                              2 MDF sealed boxes, piano black finish, four isolation feet, detachable grilles
Amplification                   Stereo 2 channels x 25 watts @ 8 ohms, class D
Drivers (MTM array)       Woofers: (2) 3.5-inch CPP    Tweeter:  (1) .75-inch silk dome
                                                Passive Radiator: (1) 4-inch bottom mounted
Inputs                                   Digital, SKAA wireless and Bluetooth 4.0 with aptX and AAC wireless
                                                Analog, stereo RCA L/R In and 3.5mm AUX In
Outputs                               Digital, SKAA wireless and Analog, stereo RCA L/R Pre-out
SKAA Audio                        Range: Up to 150 ft, 20Hz – 20 kHz, 48 kHz x 16 bit stereo, Latency: 36ms, fixed
Frequency Response     100-20K +/- 3 db
Sensitivity                           88 db
Power                                   90-240VAC / 50-60 Hz
Dimensions                        5.7” W x 11.2” H x 8.5” D (145mm W x 285mm H x 215mm D)
Unboxed Weight             Right: 9.25 lbs., 4.2 kg   Left: 7.72 lbs., 3.5 kg
Price and Availability
The Atlantic Technology FS-252 loudspeakers are now shipping internationally at $749/pr (USD).
Atlantic Technology is also expected to roll-out several more SKAA products in 2019 including an integrated amp, a sound bar, headphones and more.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
