Loudspeakers
Atlantic Technology Brings its Award-Winning Design and Sound to New Entry Level Home Theater Speaker Package
Atlantic Technology has introduced the System 1200, a 5.1-channel speaker package that delivers high quality home theater sound at a modest cost of just $1200. The system consists of five identical full-range two-way satellites and a powerful 125 Watt, 10-inch subwoofer.
“Atlantic has always been known as a ‘bang-for-the-buck’ manufacturer, and for our dedication to providing performance speakers for people who love movies,” said Atlantic Technology Chairman and Founder Peter Tribeman. “This system gives consumers the sort of experience that makes home theater so marvelous, at a cost that won’t break their bank account.”
The System 1200 LR speakers are attractive two-way sealed box bookshelf style loudspeakers. Each utilizes a 4-1/2 inch GLH (Graphite Loaded Homopolymer) woofer to provide high fidelity reproduction of the crucial upper bass and midrange frequency range, so important for providing clear and intelligible dialog. An advanced 1-inch ferrofluid cooled, damped soft dome tweeter with a powerful neodymium magnet structure is employed for high frequencies, giving the speakers their precise imaging characteristics and spacious sound. Each speaker is magnetically shielded for use next to video displays.
The deep bass reproduction for the system 1200 is handled by the powerful 125-watt Model 212 SB powered subwoofer. The 212 SB features a heavily braced sealed-box enclosure to house a 10-inch long-throw composite cone that uses a 2-inch, four layer vented aluminum voice coil to generate linear bass response from 30 to 150 Hz (+ /– 3 dB). It features line level inputs, level and crossover adjustments, phase inversion switch, and even low level outputs for daisy chaining multiple subwoofers together. It also incorporates Atlantic’s exclusive Clear Filter Technology, which actually eliminates the deleterious effects that the subwoofer’s enclosure itself can have on the sound.
The Atlantic Technology System 1200 LR satellites are available in an attractive maple finish at a suggested retail price of $145 each. The Model 212 SB is available with matching maple finish side panels at a suggested retail price of $475. The speakers are also available in finishes of gloss black or silver at a marginal cost premium.
From its inception, Atlantic Technology’s mission has been to produce home entertainment products that exemplify the very best in both performance and value. The company specializes in complete high-performance multi-channel speaker systems, state-of-the-art home theater electronics components, and products for custom audio/video installation.
Atlantic Technology speaker systems are designed and engineered at the company’s Norwood, MA facility as integrated multi-channel ensembles. These systems are tailored and tuned to provide a seamless and startlingly realistic soundstage for multi-channel music and home theater.
For more information on Atlantic Technology and its many fine products for home theater and custom audio/video installation, visit www.atlantictechnology.com or call 781-762-6300.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
