Atlantic Technology 6200e THX-Ultra2 Home Theater Speaker System Announced
Atlantic Technology has redesigned its popular System 6200 home theater speaker line with improved cabinets, pared configuration options, and lower prices, while adding THX-Ultra2 certification. The new System 6200e line does away with optional side panels and pedestal subwoofers while offering a range of more flexible configuration options suitable to any home theater or multichannel audio installation.
“This system is a classic Atlantic Technology evolution: better looks, better performance, at a lower price,” commented Atlantic Technology Director of Marketing Steve Feinstein. “The redesign has actually exceeded even our high expectations, and the new system looks better, is easier to specify and install, and costs less than the already-impressive original 6200 line. On top of all that, the LR and center channel speakers achieve a level of performance that meets THX’s elite Ultra2 performance standards – the highest certification level available for a multichannel speaker system.”
Like its predecessor, the System 6200e offers much of the industry-leading performance of Atlantic’s flagship System 8200e speaker line in a smaller form factor and at a lower price point. The 6200e LR and 6200e C speakers now feature conventional permanently attached side panels in a satin black finish, eliminating the confusion in stocking and selling the previously optional cabinet panels. Additionally, the System 6200’s original pedestal subwoofer systems have been replaced by the company’s more traditional box-style THX Certified 642e SB subwoofers, which meet their spec effortlessly and in a configuration preferred by most dealers and consumers.
Atlantic Technology’s 6200e LR floor-standing loudspeaker, and 6200 C horizontal center channel speakers are each two-way designs that are ideally timbre-matched for a coherent, seamless sound stage. Each speaker includes a sophisticated set of acoustic controls to tune performance for a variety of rooms and placement options, including High Frequency Energy adjustment for acoustically bright or dull rooms, a Location control to compensate for the acoustic effects of a pull-down screen, and a Boundary Compensation toggle that adjusts speaker output to compensate for placement near a wall or within a cabinet.
The Atlantic Technology System 6200e has been designed to integrate ideally with Atlantic’s THX Certified system 4200e dipole surround speakers, delivering a completely convincing surround field. The system is available in a wide range of configurations for home theater multichannel surround installations. Retail prices begin at $6,500 for a 5.1-channel system.
From its inception in 1989, Atlantic Technology’s mission has been to produce home entertainment products that exemplify the very best in both performance and value. The company specializes in complete high-performance multi-channel speaker systems, state-of-the-art home theater electronics components, and products for custom audio/video installation. For more information on Atlantic Technology and its many fine products for home theater and custom audio/video installation, visit www.atlantictechnology.com or call 781-762-6300.
Atlantic Technology System 6200e Specifications
Model 6200e LR 6200e C 4200e SR
Type: Sealed-box 2-way
D’Appolito array
Sealed-box 2-way
D’Appolito array
Sealed-box
Dipole/Bipole surround
Woofer (2) 6.5″ GLH 2) 6.5″ GLH (2) 4 1/2″ GLH
Tweeter (1) 1″ silk dome (1) 1″ silk dome (2) 1″ silk dome
Frequency Response 50Hz – 20kHz A±2dB 50Hz – 20kHz A±2dB 80Hz – 20kHz A±3dB
Nominal Impedance 6I© 6I© 8I©
Crossover Frequency 2.5kHz 2.5kHz 3kHz
Crossover Type Computer designed Butterworth 4th order
asymmetrical (time-aligned) Linkwitz-Riley
Sensitivity 90dB 90dB 90dB
Recommended Amplifier Power Rating 15 ‘” 150 watts RMS 15 – 150 watts RMS 10 – 150 watts RMS
Magnetic Shielding Yes Yes No
Dimensions w/ grilles 7.8 x 23.5 x 14.3in 22.5 x 11.1 x 11.5in 10.9 x 12.4 x 7.5in
(W x H x D) 194 x 584 x 356mm 560 x 276 x 285mm 277 x 315 x 191mm
Weight (ea) 26 lbs; 11.8kg 25 lbs; 11.3kg 20 lbs; 9.1kg
Model 642e SB
Type/Features -Powered subwoofer, sealed enclosure
-High efficiency tracking amplifier
-2-inch, four layer vented aluminum voice coil, vented motor
-Continuous 40-140Hz crossover, 18dB/octave low pass output
-Variable low level stereo inputs and low level outputs
-Absolute phase invert switch
-Auto signal sensing on/off/bypass
Bass Driver 12″ long-throw composite cone
Output Power 300 watts RMS
Distortion (amplifier) < 0.5%
Frequency Response 25Hz – 300Hz A±3 dB
Peak Output 105dB SPL into 2000 cubic Feet
Dimensions (WxHxD) 19 x 21 x 20.5in; 483 x 534 x 521mm (Depth w/grille)
Weight 65lbs/29.5kg
Power Requirements 110V AC 50/60Hz; 240V AC 50/60Hz
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
