Atlantic Technology 2400 Home Theater Speaker System
Improved Performance and Aesthetics
Atlantic Technology today introduced their new System 2400 series of home theater speakers, replacing the company’s popular System 2200 series. The series consists of a compact, high performance LR front speaker, a matching horizontal center channel, and a switchable dipole/bipole surround speaker. The speakers are designed for use as a dedicated home theater system when used in combination with any of the company’s newly redesigned SB line of powered subwoofers.
The most significant change to the System 2400 is the inclusion of Atlantic’s exclusive Low Resonance Tweeter (LRT™) in the 2400 LR and 2400 C front soundstage models. This tweeter, which handles a greater portion of the midrange frequency than conventional designs, improves midrange dispersion for better dialogue reproduction and soundstage coverage than conventional satellite speaker designs.
The 2400 LR front speakers each feature a pair of 4 1/2″ woofers vertically flanking a single LRT tweeter. This arrangement gives the speakers extremely linear horizontal dispersion for a broad “sweet spot,” while also limiting the vertical dispersion to prevent unwanted reflections from the floor or ceiling.
The 2400 C center channel features a pair of 4 1/2″ woofers arranged horizontally with a raised LRT tweeter between them to ensure highly intelligible dialogue reproduction for movies and multichannel music. The rear panel includes a pair of controls that can adapt sound quality for different speaker placements: A three-position High Frequency Energy switch adjusts for rooms that are acoustically too bright or too dull. A Boundary Compensation toggle can be used to adjust the lower-midrange output to compensate for the sound colorations caused by placing a speaker close to a TV screen, or building it into a cabinet or shelving unit. Finally, Atlantic’s tilting base design allows the speaker to be aimed directly at the listeners for optimum reproduction.
For surround channel reproduction, the 2400 SR surround speakers consist of two 4-1/2-inch woofers and two 1-inch soft dome tweeters in a dipole arrangement, which produces a diffuse and enveloping soundfield preferred for viewing movies. The speaker also includes a dipole/bipole select switch for situations where bipole speaker operation is preferred, including multichannel music reproduction.
The Atlantic Technology System 2400 speakers will feature attractive satin black finishes, with the 2400 LR and C also available in gloss black, and will be available in late May. Suggested retail price for the 2400 LR is $650 per pair; suggested retail price for the 2400 C is $400 each; suggested retail price for the 2400 SR is $700 per pair.
From its inception, Atlantic Technology’s mission has been to produce home entertainment products that exemplify the very best in both performance and value. The company specializes in complete high-performance multi-channel speaker systems, state-of-the-art home theater electronics components, and products for custom audio/video installation.
Atlantic Technology speaker systems are designed and engineered as integrated multi-channel ensembles, and hand assembled at the company’s Norwood, MA facility. These systems are tailored and tuned to provide a seamless and startlingly realistic soundstage for multi-channel music and home theater.
2400 LR 2400 C 2400 SR
Type Sealed-box 2-way M-T-M aray Sealed-box 2-way M-T-M array Sealed-box dipole/bipole surround speaker
Woofer [2] 4-1/2″ GLH [2] 4-1/2″ GLH [2] 4-1/2″ GLH
Tweeter [1] 1″ LRT soft dome [1] 1″ LRT soft dome [1] 1″ LRT soft dome
Frequency Response 90Hz – 20kHz +/- 3 dB 90Hz – 20kHz +/- 3 dB 90Hz – 20kHz +/- 3 dB
Nominal Impedance 8 Ohms 8 Ohms 8 Ohms
Crossover Frequency 2.3 Hz, 3rd order 2.3 Hz, 3rd order 3.5 Hz, 2nd order
Sensitivity 90dB 90dB 90dB
Recommended Amplifier Power 10-140 Watts RMS 10-140 Watts RMS 10-140 Watts RMS
Magnetic Shielding Yes Yes No
Dimensions w/ grilles (w x h x d) 6.375 x 12.94 x 7 14.625 x 7.5 x 7 11.125 x 10.5 x 7.5
Weight (each) 9 lbs. 9 lbs. 12 lbs.
Finishes gloss black / satin black gloss black / satin black satin black
MSRP $650/pair $400/ea $700/pr
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
