ATI 6000 Series Signature Amplifiers
ATI AT6000 Signature Amplifier
Top-of-the-line Amps Offer Pure Balance Design, Thermaltrak Output Devices and DC Servos
Amplifier Technologies, Inc. (ATI) today introduced their first new series of amplifiers in over a decade. The new 6000 series power amps are designed by their president and chief engineer, Morris Kessler, and are available with 2 to 7 channels, priced from $4k to $8k. Furthermore, their “signature series” designation with a facsimile of Kessler’s signature on the main panel acknowledges the special nature of these designs.
Beyond Kessler’s personal identification, these amplifiers are new in more significant ways.
  1. As in Kessler’s previous top-of-the-line designs, these amplifiers are fully balanced, differential amps, but unlike his earlier balanced designs which were essentially balanced bridged amplifiers, the 6000 series uses only a single input stage with dual-differential output stages. The reason: the advantages of balanced designs are retained and noise is reduced by 50%.
  2. The design uses current feedback instead of the more common voltage feedback. The reason: current feedback amplifiers are faster with virtually unlmited slew rate and are better able to reproduce today’s best music and film.
  3. Kessler used Thermaltrak output devices for the 6000 series. Unlike traditional designs where external diodes attached to the heat sinks track the amplifiers operating conditions and use the details to adjust bias, Thermaltrak devices have the diodes in the same package as the transistors. The results: bias is optimized in real-time.
  4. The 6000 series use dual DC servos to track and maintain DC offset. The result: DC in the amplifier’s output is reduced to insignificant levels.
  5. These amplifiers use a revised PCB layout. They are still modular with the complete amplifier including the power supply parts on a single card, but now the AC components are on one edge of the board and away from the signal input. The result: improved signal-to-noise performance.
  6. All of the amplifiers in the series use dual toroidal transformers, dual power switches and dual line cords. The results: the AT6002 is now a complete dual-mono design and the amplifiers with many channels, as in the 7-channel AT6007, can be hooked-up to two independent 20 amp circuits for greater sustained output power than is possible from a single AC circuit.
All the amplifiers in the 6000 series are rated at 300 Watts RMS from 20 Hz to 20 kHz with no more that 0.03% THD at 8 ohms with all channels driven and 450 Watts RMS at 4 ohms under the same conditions. Signal-to-noise ratio is typically 128 dB referenced to full output so each amplifier in the series is capable of playing back the full dynamic range available on today’s lossless recordings.
Pricing: MSRP
AT6002 Stereo Signature Amplifier $3,995
AT6003 3-channel Signature Amplifier $4,795
AT6004 4-channel Signature Amplifier $5,595
AT6005 5-channel Signature Amplifier $6,395
AT6006 6-channel Signature Amplifier $7,195
AT6007 7-channel Signature Amplifier $7,995
All ATI amplifiers are available in standard (17”) and rack-mount (19”) chassis with domestic (117V) of Export (220 to 240V) chassis and are covered by ATI’s 7-year transferrable warranty.
About Amplifier Technologies
Amplifier Technologies owns the ATI, Audioaccess, B&K, BGW and Theta Digital brands and designs and manufactures state-of-the-art audio components for its own and other brands in its facility in Montebello, CA. Guided by legendary amplifier designer Morris Kessler, ATI offers both performance and value in audio components.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
