ASUS ZenFone Zoom Best Smartphone Camera?
ASUS ZenFone Zoom Lens
World’s Thinnest 3X Optical-Zoom Smartphone With 10-element Lens
ASUS introduced ZenFone Zoom, the world’s thinnest 3X optical-zoom smartphone with optical image stabilization, real tone flash and laser auto-focus to eliminate shakes and blurred shots. The 5mm thin metal unibody phone (model ZX551ML) has a 5.5-inch 1920×1080 (403 ppi) Full HD IPS display, with a protruding camera. Meanwhile, the cover-glass and touch-panel layers eliminates the air gap, bringing everything closer to the user’s touch.
The phone uses a 13-megapixel Panasonic SmartFSI image sensor that claims to capture more light and color than any other smartphone. The innovative 10-element digital eye was created by the optics experts at Hoya. Glass, synthetic and prismatic lenses are meticulously configured in a dual-prism periscope arrangement to maximize incoming light and capture the best possible photo quality. Built-in optical image stabilization (OIS) ensures sharper, steadier shots every time, even at maximum 3X optical magnification. ZenFone Zoom’s OIS enables users to shoot with slower shutter speeds for longer exposures, equivalent to up to four stops. ASUS says that means your photos are clearer and brighter.
The rear camera benefits from dual-LED Real Tone flash to capture lifelike colors and skin tones for indoor photos. Furthermore, the camera’s laser auto-focus adjust in just 0.2 seconds. ZenFone Zoom even has an integrated a safety loop and many stylish strap options, for confident shooting from any angle. Not to be forgotten, the battery is said to recharge to 60% in just 39-minutes. ASUS says that allows it to recharge 3.4x faster than typical smartphones. Rounding out the feature set, this phone offers Category 4+ LTE, 802.11ac Wi-Fi, four laser-engraved antenna, and improved audio. However, most users would likely buy this phone just for the camera. Early reviews says that it lives up to expectations.
ASUS ZenFone Zoom Smartphone
Price and Availability
ASUS ZenFone Zoom (model ZX551ML) is available now unlocked for $549 in white or black. Learn more about the phone at the ASUS product page.
ASUS ZenFone Zoom Rear Camera
Specifications
  • PlatformAndroid 5.0 (Lollipop)(With ASUS ZenUI)
  • ColorBlack/White
  • Dimensions158.9 x 78.84 x 5 inch ~ 11.95 (WxDxH) cm
  • Weight6.53 oz (with battery) / 185 g
  • CPUIntel Atom Quad Core Z3580 (2.3GHz), PowerVR G6430, with OpenGL 3.0 support
  • Memory4GB LPDDR3 RAM
  • Storage64GB eMMC Flash, 5GB free lifetime ASUS WebStorage
  • Memory SlotMicroSD card (up to 64 GB)
  • ModemIntel 7262
  • Connectivity Technology
    WLAN 802.11 a/b/g/n/ac
    USB
    Bluetooth V4.0+EDR , NFC
    One Micro SIM card
    SIM1 Support2G/3G/4G
  • Network Standard
    GSM/GPRS/EDGE/WCDMA/HSPA+/FDD-LTE
    Data Rate:
    HSPA+: UL 5.76 / DL 42 Mbps
    DC-HSPA+: UL 5.76 / DL 42 Mbps
    LTE Cat4:UL 50 / DL 150 Mbps
    2G : GSM :
    850MHz/900MHz/1800MHz/1900MHz,
    3G : WCDMA :
    850MHz(5)/850MHz(6)/900MHz(8)/1900MHz(2) /2100MHz(1)
    4G : LTE Bands: (TW/JP version)
    2100MHz(1)/1900MHz(2)/1800MHz(3)/850MHz(5)/2600MHz(7)/900MHz(8)/1800MHz(9)/800MHz(18)/850MHz(19)/700MHz(28)
  • Navigation: GPS/GLONASS/QZSS/SBAS/BDS
  • Display5.5-inches, Full HD 1920×1080/403 PPI, IPS, Corning Gorilla Glass 4
  • Battery3000 mAh Li-Polymer (non-removable)
  • Front Camera: 5-Megapixels
    Wide View
    PixelMaster
    Selfie Panorama (up to 140˚)
  • Rear Camera:  13-megapixels
    Auto Focus
    0.03 second laser auto-focus
    Close-up macro photography (5 cm)
    LED Flash
    PixelMaster
    Dual-color Real Tone flash
    Back Light (HDR) mode with ASUS PixelEnhancing Technology for up to 400% brighter , and evenly exposed photos
    Low Light mode with ASUS PIxelMaseter Technology for up to 400% brighter photos and videos
    Manual Mode for DSLR-like camera detail settings
    Super resolution mode for up to 52x resolution photos
    Real Time Beautification
    10-element lens
  • Audio Slot3.5mm
  • SensorsAccelerator/E-Compass/Gyroscope/Proximity/Ambient Light Sensor/Hall Sensor
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
