Loudspeakers
ASUS SP-BT23 Bluetooth Portable Speaker Announced
Provides Ideal Portable Option for Wireless Audio Enjoyment
Catering to users who like to listen to music on-the-go, ASUS, producer of high quality audio products, has today released the new ASUS SP-BT23 Bluetooth Speaker. Stylishly white and compact in size, it is highly portable and embodies the three E’s of “Easy to Carry”, “Easy to Share” and “Excellent Audio Quality”. This “Eee” Speaker is thus able to wirelessly provide users with crystal clear sounds – making it the ideal choice for listening to music in outdoor activities or on-the-move.
Easy to Carry with Compact and Lightweight Design
With dimensions of only 170(W) x 123.5(H) x 54(D) mm a weight of just 400g, the SP-BT23 Bluetooth Speaker is lightweight and easy to carry — making it perfect for users to listen to music while engaging in outdoor activities like picnics, hiking trips and so on. Users need only connect it to an AC/DC 100~240V power supply, or just add 4 AA batteries to be able enjoy listening to their favorite tunes anytime, anywhere.
Easy to Share with Wireless Bluetooth
The SP-BT23 is also fully compatible with any wireless device equipped with a Bluetooth audio output (A2DP profile), which includes notebooks with built-in bluetooth modules, ASUS mobile phones like the ASUS P735/ P526/ P535/ P550/ P527/ P750/ M530W; and MP3 players. It is also a perfect companion to the Eee PC — providing online music from the web, viewing online movie clips or even enhancing video conferencing conversations! In the event where wireless inputs aren’t available, the SP-BT23 is also equipped with an analogue audio line-in jack with a built-in audio wire in the cover for quick input access.
With an audio output power of dual 2W speakers and a frequency response of 150Hz ~ 20KHz, the SP-BT23 provides premium stereo quality sounds to suit your every audio need. Working hand in hand with the uniquely shaped design, users will be able to utilize its two acoustic modes which are easily accessed via a switch for different audio options in various positions. Additionally, the speaker unit is equipped with a cover design that helps protect the speakers from dust and damage.
Specifications
Bluetooth
Standard Bluetooth V1.2 Class2
Bluetooth Profile Advanced Audio Distributed Profile (A2DP)
Device Name SP-BT23
Pin Code 0000
Power
Power Source AC: 100 ~ 240V (50~60Hz); DC: 5V, 1200mA; or 4xAA batteries
Speaker (by 1KHz)
Max Power Output 4W (2Wx2)
RMS Power Output (T.H.D.=10%) 1.6±0.3W
S/N Ratio 70dB
Driver Units 1″, 4Ω 2W
Sound Frequency
Frequency Response 150Hz ~ 20KHz
Average Sound Pressure Level 77dB
Resonant Frequency Fo=280Hz
Others
Product Dimensions 170(W) x120(H) x 54(D)mm
Weights 400g
Naim CI-Uniti 102 Streaming Amplifier Angle
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Sony UBP-X700/K 4K Blu-ray Disc Player Tray Open Front Angle Sony UBP-X700/K 4K Blu-ray Disc Player Tray Open Front Angle
At $300, Sony is going to make UHD 4K fans both happy and somewhat upset with new UBP-X700/K Blu-ray disc player for 2025.
Triangle BR04 Stand-mount Loudspeakers in Chestnut Lifestyle Triangle BR04 Stand-mount Loudspeakers in Chestnut Lifestyle
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Philips Roku 65-oinch OLED TV Philips Roku 65-oinch OLED TV
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Rotel DX-3 Black Angle Front Lifestyle with Headphones Rotel DX-3 Black Angle Front Lifestyle with Headphones
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Q Acoustics Q SUB Subwoofer Series in Satin Black Q Acoustics Q SUB Subwoofer Series in Satin Black
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
Sony's smallest speaker with ULT Power Sound, the ULT Field 1 packs a punch in a portable package.
Bose goes smaller with the introduction of the SoundLink Micro. The $110 Bluetooth rugged speaker is rated IPX7 waterproof and measures just 3.75 inches...
LG has introduced its most powerful portable Bluetooth speaker along with a small go-anywhere speaker. Which one is right for you?
