ASUS RT-N13U Wireless Router
An Easy-to-use, High-speed Wireless Router with Printer Server Capabilities and Improved Versatility
The ASUS RT-N13U wireless router is the latest in the line of quality routers from ASUS that aims to provide users with a host of easy-to-use wireless features. Among them, the EZ UI lets users set up and manage wireless connections, printers, and scanners with exceptional ease. It also facilitates troubleshooting, sharing of multimedia content and documents, as well as the allocation of bandwidth to different activities based on user preferences. With more wireless connectivity options, the ASUS RT-N13U can also support 24/7 downloads–even when the PC is turned off. It is also a stylish performer that complements any home or office with its clean design and hidden internal antenna.
Configure an All-in-one Printer Easily with EZ UI
The ASUS RT-N13U wireless router features EZ UI, a powerful graphical user interface that provides intuitive setup and easy management of printers and other networked resources. It features a suite of innovative connectivity solutions including EZ All-in-One Printer, QIS, Ai Disk, Dr. Surf, EZ QoS, and Network Map.
EZ All-in-One Printer allows multiple users to share printers and scanners without a dedicated server managing the process. It increases office efficiency by handling multiple printing requests simultaneously. Additionally, convenient scanning can be done on the printers with auto-installation of drivers. No loading of additional programs is required. For easy configuration, EZ All-in-One Printer supports and detects all the major printer brands on the market.
QIS (Quick Internet Setup) facilitates device connection to the Internet in three easy steps. With Ai Disk, users can easily set up a file-sharing server at home in three simple steps. Dr. Surf offers real-time diagnostics for rapid troubleshooting. EZ QoS lets users easily prioritize application bandwidth for an optimal experience. Network Map provides a complete overview of network status for easy monitoring.
Set Up Effortlessly with EZ Switch
For more advanced users, the ASUS RT-N13U features the exclusive EZ switch with three modes to meet various wireless network requirements. If a user wants to set up an ADSL network at home, they can set the EZ Switch to router mode, whereas if they want to use wireless connectivity, the EZ Switch can be set to repeater mode. Lastly, if the user has another router at home, they may choose the AP mode, which allows them to share the network.
Internal Antenna–A Stylishly Well-received Connection
Another innovative feature of the ASUS RT-N13U is its design. It features an internal antenna, which provides wider coverage than an external antenna. Furthermore, with an optimized antenna isolation configuration, users can get even better connectivity, as well as extremely clear reception for the best performance with minimal adjustments. Finally, with a clean and minimalist exterior, the ASUS RT-N13U is a stylish and contemporary addition to any home.
ASUS RT-N13U Specifications
Hardware
Ethernet Port WAN x 1, LAN x 4 RJ-45 for 10/100 BaseT
Supports Ethernet and 802.3 with max. bit rate 10/100Mbps and auto cross-over function (MDI-X)
Antenna 2 x PCB antenna
Antenna Gain in 1~3dBi
Power Adapter DC output 12V with max. 1A current
Dimensions 165mm x 125mm x 30mm
Weight Device: 265g w/ Packing: 770g
Wireless LAN
Operating Frequency 2.4~2.5GHz
Data Rate 802.11n Draft up to 300Mbps
802.11g 6, 9, 12, 18, 24, 36, 48, 54Mpbs
802.11b 1, 2, 5.5, 11Mbps
Output Power n mode: 15.8~19.5dBm
g mode: 15.5~16.5dBm
b mode: 15.8~19.5dBm
Receiver Sensitivity
(at normal temp. range)
75~ -77dBm @54Mbps
89~ -92dBm @11Mbps
91~ -95dBm @1Mbps
Encryption/Authentication Supports 64/128-bit WEP
WPA-PSK, WPA2-PSK
WPA-Enterprise, WPA2-Enterprise
Radius with 802.1x
Software
Management EZ QoS (Easy Quality of Service): Allows multiple network activities (FTP, Game, P2P) to work smoothly at the same time
DHCP Server: Supports up to 253 IP addresses; Changeable DHCP lease time, IP pool, domain name; Static mapped IP
Web-based administration: Supports IE 5.5 or later, Firefox 2.0.0.1 or later; Managed from LAN and Internet; Password Setting
System Event Log
Firmware Upgrade: Web Interface, Bootloader
Save/Restore Configuration File
Internet Connection Type Automatic IP, Static IP, PPPoE (MPPE supported), PPTP, L2TP
Security Firewall: NAT and SPI (Stateful Packet Inspection), intrusion detection including logging
Logging: Dropped packet, security event, Syslog
Filtering: Port, IP packet, URL keyword, MAC address
ASUS Wireless Routers with EZ UI Features
Products QIS Network Map Dr. Surf Ai Disk EZ QoS EZ All-in-One Printer Server Availability
RT-N15 Yes Yes Yes No Yes No June 2009
RT-N13U Yes Yes Yes Yes Yes Yes July 2009
RT-N13 Yes Yes Yes No Yes No January 2009
WL-500gP V2 Yes Yes Yes Yes Yes Yes December 2008
WL-520GU Yes Yes Yes No Yes Yes December 2008
WL-600g Yes Yes Yes Yes Yes Yes July 2009
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
