Gaming Notebooks
ASUS ROG G750JZ, JM and JS Gaming Notebooks
ASUS G750JZ Gaming Notebook
ASUS Republic of Gamers (ROG) just announced the G-Series G750JZ, G750JM and G750JS high-performance gaming notebooks. The latest G750 models feature a 4th-generation Intel Core i7-4700 processor and the brand-new enthusiast-level NVIDIA GeForce GTX 800M Series GPUs, and include exclusive ASUS TurboMaster GPU-overclocking technology to deliver desktop-grade gaming performance.
TurboMaster is bundled with a version of the GPU Tweak utility that’s specifically designed for the new G-Series notebooks. GPU Tweak makes GPU overclocking easy and uses parameters that ensure long-term stability, even during extended overclocking experiments. TurboMaster lets users easily and safely overclock the GPU by up to 5% for even more extreme performance
The GTX 800M Series GPUs also include support for two NVIDIA technologies — Battery Boost and ShadowPlay — that are specifically designed to enhance mobile gaming. NVIDIA Battery Boost automatically gives up to a 2X improvement in battery life while gaming, and NVIDIA ShadowPlay allows gamers to capture and share their greatest gaming moments — automatically.
The new G750 notebooks have an upgraded thermal solution that uses intelligent dual independent fans with copper heatsinks, so they will never lose their cool in the heat of battle, even during those all-night gaming sessions. Both the processor and GPU each have their own independent and powerful heat-pipe-based cooling that is automatically optimized according to the demands on the system. Its unique rear-vented thermal design means that distracting fan noise is kept to a minimum while maximizing cooling efficiency.
The new G750 models add support for the latest 4K/UHD (ultra-high-definition) displays, and its Trinity display technology means that up to three separate external displays can be connected simultaneously using the HDMI 1.4 and DisplayPort 1.2 interfaces.
Wireless network performance is critical for uninterrupted online gaming, so G750 uses the very best wireless solution available – the Killer™ Wireless-N 1202. With its dual-band, dual-stream MIMO (Multiple-input, Multiple-output) design, G750 delivers rock-solid speeds of up to 300Mbit/s on both the 2.4GHz and 5GHz frequency bands. And with built-in Bluetooth, Wi-Fi Direct technology for direct (peer-to-peer) connections and Advanced Stream Detect technology intelligently prioritizes game-related traffic.
Using the power of ASUS SonicMaster audio technology and the unique Bass Eye built-in subwoofer, G750 delivers majestic full-range 2.1 sound that puts gamers right in the center of the action. Precision control of audio settings is provided by the exclusive ROG AudioWizard with its five preset audio profiles, so getting the perfect sound for any kind of entertainment is simple. Users can also create their own custom settings for instant use at any time.
Additional features include anti-glare screen, large multi-touch touchpad, cool white-backlit one-piece keyboard with long-travel (2.5 mm) keys, and hi-fi-quality headphone amplifier with support for high-end 600 ohm headphones.
Pricing and Availability
ASUS G750JZ, G750JM and G705JS will be available soon.
Specifications
Processor
Intel Core i7-4700HQ Processor
Graphics Card
G750JZ: NVIDIA GeForce GTX 880M with 4GB GDDR5 VRAM
G750JS: NVIDIA GeForce GTX 870M with 3GB GDDR5 VRAM
G750JM: NVIDIA GeForce GTX 860M with 2GB GDDR5 VRAM
Operating system
Windows 8.1 (Standard or Pro)
Display
17.3-inch anti-glare Full HD (1920 x 1080) with LED backlight
Memory
DDR3 1600 MHz up to 32GB
Storage options
2.5-inch SATA 1TB/1.5TB (5400rpm)
2.5-inch SATA 750GB/1TB (7200rpm)
2.5-inch SATA 750GB (5400rpm, SSH)
2.5-inch SATA 256GB SSD
256GB SSD x 2 / 128GB SSD x 2 (default RAID 0)
Dual hard disk drive support
Optical drive
DVD Super-Multi / Blu-ray combo / Blu-ray writer
Camera
Built-in HD webcam and array mic
Size
41.0 x 31.8 x 1.7 ~ 5.0cm
Weight
4.5kg (with 8-cell Battery)
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
