Max Performance in a Mini Form Factor
ASUS, the world’s leading motherboard manufacturer released the X58-based ROG (Republic of Gamers) Rampage II GENE in response to increased demand for a micro ATX gaming and enthusiast motherboard. Hailing from ASUS’ world record-breaking Rampage II lineage, the Rampage II GENE boasts premium features such as MemOK! for worry-free memory upgrades, CPU Level Up for easy system performance boosts, and onboard SupremeFX X-Fi for true-to-life surround sound.
Miniature Size, Maximum Power
With the Rampage II GENE, ASUS has masterfully filled the micro ATX gap with its lauded ROG product line. Users can now harness the full power of the Intel Core i7 processor in a chassis the fraction of the size and weight of standard desktop PCs. The Rampage II GENE’s awesome combination of overclockability, tweakability and stability enable it to even outgun other full-sized motherboards.
MemOK! Any Memory is A-Okay!
MemOK! was developed to provide users with a worry-free memory upgrade experience. In the event of a boot failure after installing new RAM, all the user has to do is press an easily accessible button on the motherboard and MemOK! automatically loads the failsafe settings needed to ensure a successful system boot. MemOK! rapidly detects and resolves memory issues–even if bad or unstable memory is used!
Supreme In-game Audio with SupremeFX X-Fi
An onboard SupremeFX X-Fi solution delivers crisp audio and incredibly realistic in-game sound effects. Official EAX sound effects from EAX 1.0 to EAX HD4.0 allow gamers to enjoy total immersion in supported games. X-Fi CMSS3D’s groundbreaking positional audio gives gamers a distinct in-game advantage, while Crystalizer enhances overall audio quality dramatically.
Specifications
Model | Rampage II GENE |
CPU | LGA1366 socket for Intel Core i7 |
Chipset | Intel X58/ICH10R |
System Bus | Up to 6.4 GT/s with QuickPath Interconnection |
Memory | 6 x DIMM, Triple Channel, up to 24GB DDR3 2000(O.C.)/1800(O.C.)/1600(O.C)/1333/1066 MHz |
Expansion slot | 2 x PCIe2.0 x16 slot, supports dual x16 1 x PCIe2.0 x4 1 x PCI 2.2 |
Multi-GPU | Support NVIDIA SLI / ATI CrossFireX |
Storage | 7 x SATA 3.0 Gb/s 1 x eSATA 3.0 Gb/s 1 x UltraDMA 133, support RAID 0, 1, 0+1, 5, and JBOD |
LAN | Gigabit LAN |
Audio | Onboard SupremeFX X-Fi 8-Ch. Audio with EAX4.0 support |
Other I/O ports | 1*PS/2, 1*eSATA, 1*IEEE1394a, 1*Clr CMOS, 1*Optical S/PDIF |
USB / IEEE1394a | 12 x USB2.0 (6+6) / 2 x 1394a ports (1 at back I/O, 1 onboard) |
Fan connector | 5 (1 x CPU / 2 x Chassis / 2 x Optional) |
Software (Full version) | Kaspersky anti-virus, Futuremark 3DMark06 Advanced Edition |
Features | MemOK!, CPU Level Up, Keyboard-TweakIt, Extreme Tweaker, iROG, Loadline Calibration, LCD Poster, EPU-6 Engine, Q-Fan plus, Voltiminder LED |
Form Factor | micro ATX Form Factor, 9.6″x 9.6″ (24.4cm x 24.4cm) |
