ASUS ENGTS450 Graphics Cards
ASUS announced the latest addition in its Fermi-based high-performance DirectX 11 graphics cards — the ENGTS450 DIRECTCU Series.
The ASUS ENGT450 graphics cards feature NVIDIA's latest GeForce 400 GPU design that delivers impressive DX11 graphics plus support for exciting technologies like NVIDIA 3D Vision, PhysX and CUDA and enhanced tessellation. The ASUS ENGTS450 DirectCU TOP lineup goes further than reference solutions with a focus on quality, reliability and performance. These facets are driven through features like DirectCU thermal design, Voltage Tweak overvolting and reliability features like GPU Guard, EMI Shield, Fuse Protection and a Dust Proof Fan Design. These innovative features ensure enhanced cooling, frame rate, reliability and allow for superior overclocking, continuing to show ASUS' focus at providing the best performance and value for the budget gamer who does not want to sacrifice quality or performance.
Better Cooling with Copper — DirectCU Technology
Continuing to set the bar in graphics cooling designs, ASUS continues its use of its award winning DirectCU thermal heatsink and fan assembly design.
The ENGTS450 DirectCU performs 20% cooler and 35% quieter with DirectCU thermal technology as well as ensuring quiet and cool operation even when overclocked. The use of top quality components ensures that the ENGTS450 DirectCU Series stays stable during overclocking and durable for long-term use.
Pushing Boundaries Further with TOP selected GPUs
ASUS ENGTS450 DirectCU TOP/DI/1GD5 graphics cards continue with the award winning TOP design with sorted GPUs featuring factory overclocks for improved gaming and benchmarking. The ASUS ENGTS450 DirectCU TOP series feature Voltage Tweak technology that allows adjustment of voltages to the GPU for superior overclocking and higher frame rates. Voltage Tweak in unison with the award winning fan controls offered in Smart Doctor graphics utility allow for flexibility and safety when overclocking. These features can boost the core and memory clocks significantly for faster overall performance* in your games, applications, or benchmarks.
Elevating Gaming and Multimedia To A New Level Of Immersion
Dedicated gamers and media enthusiasts need look no further than the power of NVIDIA's new GTS450 chipset in the ASUS ENGTS450 series of graphics cards. These cards open up new horizons of visual fidelity with native DirectX11 capabilities and resolutions up to 2560 x 1600. Finally, true high definition gaming comes to life in vivid detail with the added advantage of NVIDIA 3D Vision technology allowing for the most immersive gaming and cinema experience.
Product highlights:
  • The ASUS ENGTS450 DIRECTCU TOP/DI/1GD5 is TOP-selected and overclocked to perform at 925MHz, performing over 15% faster than reference solutions.
  • ASUS DirectCU thermal technology: Precision mounted twin DirectCU 8mm copper heatpipes are in direct contact with the GPU — creating faster heat dissipation and achieving 20% cooler performance and 35% quieter operation at 21dB (idle mode) — barely audible, even in a quiet room.
  • ASUS Voltage Tweak technology allows the ENGTS450 DIRECTCU Series to overclock to the GPUs limits, potentially allowing frequencies near 1GHz. More impressive and more covenient, the bundled ASUS Smart Doctor utility alters the GPU voltage without requiring adjusted BIOS settings, or even reboot the PC. Gamers can achieve higher frame rates on-demand and without interrupting the on-screen action.
  • ASUS ENGTS450 DirectCU levels up overclocking stability with the unique POSCAP (Capacitor) to reduce power noise. In addition ASUS ENGTS450 Series pushes forward in hardware design using a more advanced 4-phase power (compared to reference 3-phase) to provide higher current flow and more stable voltage during tweaking.
  • The exclusive PCB stiffener and GPU Guard provide extra strong hold to enhance shockproof performance and prevent bending and cracking. Plus, the Fuse Protection and EMI shield deliver risk-free graphics performance.
Availability
The ASUS ENGTS450 DIRECTCU Series are available immediately from authorized ASUS resellers. With an MSRP starting at $139.99, ASUS' 400 series extends the spectrum of features, performance, and true Windows 7 optimization to new audiences.
Specifications
ENGTS450 DIRECTCU TOP/DI/1GD5 ENGTS450 DIRECTCU/DI/1GD5
Graphics Engine NVIDIA GeForce GTS450 NVIDIA GeForce GTS450
Bus Standard PCI Express® 2.0 PCI Express® 2.0
Video Memory 1GB GDDR5 1GB GDDR5
Engine Clock 925 MHz 783 MHz
Memory Clock 4000 MHz (1000 MHz GDDR5) 3608 MHz (902 MHz GDDR5)
Memory Interface 128 bit 128 bit
CUDA Core 192 192
DVI Max. Resolution 2560 x 1600 2560 x 1600
D-Sub Max. Resolution 2048 x 1536 2048 x 1536
D-Sub Output X1 X1
DVI Output X1 X1
HDMI Output X1 (Native) X1 (Native)
HDCP Compliant YES YES
Software Bundled ASUS Utilities & Driver
AiWi
AiWi
Dimensions The card size is 8.543″ x 4.37″ The card size is 8.543″ x 4.37″
Price check price check price
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
