Desktop PC
ASUS EeeTop PC ET20 / ET22 Series All-in-One Desktop PC
Multimedia Enjoyment with a Contemporary Touch
The new ASUS EeeTop PC ET20/22 Series is a range of touch*-enabled, all-in-one PCs that provides users with the fundamentals of everyday computing and multimedia entertainment in an elegant space-saving design. Its forte lies in its ability to provide users with the ultimate home entertainment experience. The EeeTop PC ET22 and EeeTop PC ET20 feature a flushed 22-inch and 20-inch touch*-enabled display respectively that provides high definition images through the use of state-of-the-art graphics processors. The resulting visual spectacle is complemented by a surround sound experience delivered by the Dual Hi-Fi speakers with SRS Premium Sound™. The ASUS EeeTop ET20/22 Series also lets users communicate via the easy-to-use Eee Cam, while the Eee Bar gives them access to their commonly-used applications. Users can also organize their photographs with FotoFun, and leave notes for their family and friends with Eee Memo. Simply put, the new ASUS EeeTop PC ET20/22 Series is the ideal all-in-one communications and entertainment PC for the family.
The Absolute Pinnacle of High Definition Home Entertainment
The ASUS EeeTop ET20/22 Series delivers high definition multimedia entertainment at a touch*. Users can choose between a 20-inch or 22-inch flushed high definition display with a 16:9 aspect ratio. The ASUS EeeTop ET20/22 Series features a dedicated ATI Radeon™ HD4570 or NVIDIA ION™ graphics processor to deliver clear and vibrant true-to-life images, while a pair of embedded Hi-Fi speakers with SRS Premium Sound™ delivers an immersive virtual surround sound experience. Users can watch high definition movies on Blu-ray via a Blu-ray disc drive** (Available only on selected models). The ASUS EeeTop ET20/22 Series can connect to external monitors, game consoles and other home entertainment devices via HDMI-in and SPDIF outputs (only for ET22 Series). The ASUS EeeTop ET20/22 Series also features the touch*-enabled Total Media Center (only for ET22 Series)–a one-stop, intuitive interface which allows users to browse, view and organize multimedia files. These cutting-edge technologies come together to provide users with the best in home multimedia entertainment.
Discover the Power to Connect at Your Fingertips
As intuitive computing becomes ever more prevalent, the need for an instinctive user interface is more apparent. The high definition 20-inch or 22-inch touch*screen of the ASUS EeeTop PC ET20/22 Series gives users fingertip access to a suite of touch*-enabled programs. Users can leave virtual ‘sticky notes’ for their family with Eee Memo, or video messages via the embedded Eee Cam which features Real-time Image Capture technology. This exclusive technology delivers superior image quality at 30 frames-per-second*, as well as enhanced light sensitivity for low-light environments. Users can doodle or add special effects to snapshots of themselves and even create customized emoticons for use in web messaging applications such as Skype, MSN Messenger™, Yahoo Messenger and AIM. FotoFun lets users organize their customized emoticons, photographs and pictures like they would in a photo album, or upload them onto their blogs. Finally, the Eee Bar provides speedy access to commonly used applications, as well as system management settings at a single touch*.
Stylishly Designed with Space-savings in Mind
The ASUS EeeTop PC ET20/22 Series is the perfect blend of form and function. Its frameless screen and slim profile not only bring a touch of class to every home, but save space as well. Finally, an elegantly-designed stand on the rear bezel of the EeeTop PC ET20/22 Series completes the minimalist design, while providing an added touch of mobility.
Specifications
Model Name ET2002 ET2002T ET2203T
Display 20″ 16:9 Widescreen 20″ 16:9 Widescreen 22″ 16:9 Widescreen
Touch* Screen No Yes Yes
Operating System Genuine Windows Vista Home Premium (Windows 7 Upgradable) Genuine Windows Vista Home Premium (Windows 7 Upgradable) Genuine Windows Vista Home Premium (Windows 7 Upgradable)
CPU Intel Atom™ Processor 330 Dual Core Intel Atom™ Processor 330 Dual Core The Intel Core™2 Duo Processor T4300
The Intel Core™2 Duo Processor T6500
Chipset NVIDIA ION™ NVIDIA ION™ Mobile Intel PM45 Express Chipset
Graphics Card NVIDIA ION™ NVIDIA ION™ ATI Radeon™ HD 4570
Default Memory DDR2 SO-DIMM 2GB (upgradeable to 4GB) DDR2 SO-DIMM 2GB (upgradeable to 4GB) DDR2 SO-DIMM 4GB
Hybrid Storage 320GB SATAII 5400rpm 320GB SATAII 5400rpm 320GB/500GB SATAII 5400rpm
Optical Disc Drive Tray-in Super Multi Tray-in Super Multi Super Multi
Blu-ray
Wireless Data Network 802.11b/g/n 802.11b/g/n 802.11b/g/n
LAN 10/100/1000 Mbps 0/100/1000 Mbps 10/100/1000 Mbps
Camera Yes, with ASUS’ exclusive Real-time Image Capture Technology Yes, with ASUS’ exclusive Real-time Image Capture Technology Yes, with ASUS’ exclusive Real-time Image Capture Technology
Audio Codec SRS Premium Sound™ SRS Premium Sound™ SRS Premium Sound™
Speakers 3W Hi-Fi Speaker x 2 3W Hi-Fi Speaker x 2 3W Hi-Fi Speaker x 2
Built-in Mic Digital Mic Digital Mic Digital Mic
Side I/O ports USB 2.0 x 2, 3-in-1 Card Reader: SD/MMC/Memory Stick, Headset x 1, Microphone x 1 USB 2.0 x 2, 3-in-1 Card Reader: SD/MMC/Memory Stick, Headset x 1, Microphone x 1 USB 2.0 x 2, 3-in-1 Card Reader: SD/MMC/Memory Stick, Headset x 1, Microphone x 1
I/O Ports Rear:
  • Power Input(DC 19V)
  • USB Ports x 4
  • LAN Port
HDMI-Input: Standalone Monitor and game console with HDMI-In
Rear:
  • USB Ports x 4
  • LAN Port
Rear:
  • USB Ports x 4
  • LAN Port
  • S/PDIF out
Keyboard + Mouse Wireless Keyboard + Mouse Wireless Keyboard + Mouse Wireless Keyboard + Mouse
Power Supply 19Vdc, 3.42A, 65W Power Adaptor
19Vdc, 4.74A, 90W Power Adaptor
Dimensions (mm) 511(W) x 410 (H) x 53 (D) 511(W) x 410 (H) x 53 (D) 548 (W) x450 (H) x 48 (D)
Weight (kg) 7.2 7.2 8.9
Color Black Black Black
Accessories
  • Keyboard
  • Mouse
  • AC Adapter
  • Power Cord
  • Cleaning Cloth
  • Quick Start Guide
  • Warranty Card
  • Support & Recovery DVD
  • Keyboard
  • Mouse
  • AC Adapter
  • Power Cord
  • Cleaning Cloth
  • Quick Start Guide
  • Warranty Card
  • Keyboard
  • Mouse
  • AC Adapter
  • Power Cord
  • Cleaning Cloth
  • Quick Start Guide
  • Warranty Card
* Optional.
** Blu-ray slot-in drive is only available on the ASUS EeeTop PC ET2203T.
Specifications are subject to change without prior notice.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
