ASUS introduced the 10-inch Eee PC 1025C Flare Series Netbook, featuring a fresh stylistic design with the latest Intel Atom N2600 (Cedar Trail) dual-core processor. ASUS’ Instant On technology enables 2-second resumption from sleep mode and up to two weeks of standby time. 1080p video playback via built-in HDMI output and enhanced connectivity with Wi-Fi Direct is also supported.
The sleek and stylish design features flare-inspired metallic side panels along with anti-fingerprint matte finish that is fingerprint resistant. The Eee PC 1025C Flare Series comes equipped with the latest Intel Atom Cedar Trail dual-core processor clocked at 1.6GHz, supports up to 2GB of DDR3 memory and 320GB of hard drive space. Users will also receive 3GB of cloud storage space on ASUS WebStorage that allows you to easily share your files with others by dragging and dropping files in an intuitive interface. Super Hybrid Engine II technology automatically manages the battery life to give users up to 10.5 hours of on the go use with one charge.
Enjoy superior multimedia performance on the Eee PC 1025C with its HD capability. Simply connect to an HDTV via the built-in HDMI output and transform the Eee PC into your own portable HD theater. With built-in 802.11b/g/n Wi-Fi capabilities and DLNA support, users can stream music, photos, and videos to any DLNA-compatible devices in the home. Wi-Fi Direct enables users to transfer files wirelessly between the Eee PC 1025C and other devices directly without having to go through a network making it very convenient for file sharing on-the-go.
Price and Availability
The ASUS Eee PC 1025 Flare Series is available now for $329 in Paris Pink, Silky White, and Matte Black.
Specifications
- Operating System: Genuine Windows 7 Starter
- Display: 10.1″ LED Backlight WSVGA (1024×600) Screen
- CPU: Intel Atom N2600 (Dual Core; 1.6GHz) Processor
- Memory: DDR3, 1 x SO-DIMM, 1GB
- Storage: 320GB 5400rpm HDD w/ 3GB ASUS WebStorage
- Wireless Data Network: WLAN 802.11 b/g/n @ 2.4GHz
- Audio: Hi-Definition Audio CODEC and High Quality Speaker / Mic
- Battery: 6 cells Li-ion Battery Pack, battery life 12.5 hrs (6cells, 5200mAh, 56W/h)
- Dimensions: 262 x 178 x 20.7 ~34.4 mm (WxDxH)
- Weight: 1.25 Kgs (w/ 6cell battery)
- Interface:
- 1 x VGA Connector
- 3 x USB 2.0
- 1 x LAN RJ-45
- 1 x HDMI
- 1 x Audio Jack (Headphone/Mic-In)
- 1 x Card Reader : SD/ SDHC/ MMC
Danielle Carneiro
September 21, 2012 at 5:40 pm
how much will you have it for on blackfriday?
