Features Voltage Tweak Technology for up to a 38% Performance Upgrade
ASUS, the world’s leading producer of top quality, cutting edge graphics solutions, today launched the new ASUS EAH5870/2DIS/1GD5 and EAH5850/2DIS/1GD5. The first in the world to utilize Voltage Tweak technology, these graphics cards enable users to boost GPU voltages via the SmartDoctor application to enjoy up to a 38% improvement in performance. Both graphics cards support Microsoft DirectX 11 and Windows 7 to provide users with the most intense gaming experience. The latest 40nm process and GDDR5 memory technologies are also utilized to deliver faster processing times and general system performance. Users can even run up to three displays from a single graphics card, thanks to the native DisplayPort and Eyefinity technology. The ASUS EAH5800 Series comes specially bundled with DiRT 2–by far the most anticipated DirectX 11 game–pushing the boundaries of immersive gaming with true-to-life visual realism and effects.
Performance Boosts with Voltage Tweak and Extreme Overclocking with SmartDoctor
The ASUS EAH5870/2DIS/1GD5 and EAH5850/2DIS/1GD5 are equipped with Voltage Tweak technology, as part of the SmartDoctor application. It enables users to raise GPU voltages from 1.15V to 1.35V and from 1.088V to 1.4V respectively, boosting GPU and memory clock performance from 850 / 725 MHz to 1035 / 1050 MHz and from 4800 / 4000 MHz to 5200 / 5200 MHz respectively. Such extreme performance upgrades raise the EAH5870 and EAH5850’s 3DMark Vantage Extreme Preset score from 8,087 to 9,252 and from 6501 to 8987–an unbelievable 17% and 38% improvement compared to other reference designed boards*. Gamers and overclockers can also benefit from ASUS SmartDoctor, the world’s first overclocking utility that allows the tweaking of GPU voltages on the EAH5800 Series graphics cards. ASUS SmartDoctor enables users to boost both voltages and overall performance with just a few clicks–without the hassle of flashing the BIOS or running the risk of damaging the graphics card.
Taking Graphics Further with Windows 7, DirectX 11 and DiRT 2
With the ASUS EAH5800 Series graphics cards’ support for DirectX 11, it is now possible for users to enjoy new levels of visual realism while playing games and watching videos on the PC. Innovations such as HDR Texture Compression, DirectCompute and Tessellation are engineered to take advantage of all the graphical features within the new Windows 7 operating system. What’s more, the ASUS EAH5800 Series is available in a special bundle, featuring the best in off-road racing–Colin McRae: DiRT 2. Colin McRae: DiRT 2 is one of the most anticipated racing games of the year. It takes full advantage of DirectX 11, adding realism to the racing environment. Hardware tessellation improves the appearance of water and other surfaces, as well as crowd animations. Utilizing the EGO Engine, DiRT 2 sets the world of virtual rallying alight, a definite must-have for high adrenaline off-road racing on the PC.
Enhanced Processor and Memory Performance via 40nm Process and GDDR5 Memory Technologies
The ASUS EAH5800 Series graphics cards boast 40nm process technology to provide better system performance while using less power, thanks to highly efficient transistors. With advanced GDDR5 memory technology–enabling up to twice the bandwidth per pin as compared to GDDR3 memory–users can now experience the speed, responsiveness and performance of ultra-high bandwidth for processor-intensive multitasking and gaming.
Extend the View across Three Displays with Eyefinity Technology and Native DisplayPort
The ASUS EAH5800 Series graphics cards feature Eyefinity technology and native DisplayPort, allowing users to expand the field of view across up to three displays**. This allows for more detail than ever before with innovative “wrap around” capabilities that deliver an incredibly intense gaming experience, enhancing the feeling of being in the game.
Specifications
Model | EAH5870/G/2DIS/1GD5 | EAH5870/2DIS/1GD5 |
Graphics Engine | ATI Radeon HD 5870 graphics | ATI Radeon HD 5870 graphics |
Video Memory | 1GB GDDR5 | 1GB GDDR5 |
Engine Clock | 850MHz | 850MHz |
Memory Clock | 4800MHz (1200MHz GDDR5) | 4800MHz (1200MHz GDDR5) |
Memory Interface | 256 bit | 256 bit |
DVI Max. Resolution | 2560 x 1600 | 2560 x 1600 |
Bus Standard | PCI Express 2.0 | PCI Express 2.0 |
DVI Output | DVI-I (Dual Link) X2 | DVI-I (Dual Link) X2 |
HDCP compliant | Yes | Yes |
HDMI Output | Yes | Yes |
DisplayPort | Yes | Yes |
D-Sub Output | Yes (Via Adapter) | Yes (Via Adapter) |
Software Bundled | ASUS Utilities and Driver The hottest DirectX11 game: DiRT 2 |
ASUS Utilities and Driver |
Dimensions | 11 inches x 5 inches | 11 inches x 5 inches |
Model | EAH5850/G/2DIS/1GD5 | EAH5850/2DIS/1GD5 |
Graphics Engine | ATI Radeon HD 5850 graphics | ATI Radeon HD 5850 graphics |
Engine Clock | 725MHz | 725MHz |
Memory Clock | 4000MHz (1000MHz GDDR5) | 4000MHz (1000MHz GDDR5) |
Dimensions | 9.5 inches x 5 inches | 9.5 inches x 5 inches |
* Test Configuration:
PCI-Express 16X
MB: Maximus Extreme Rev: 2.00 BIOS: 0802
CPU: Intel Core2 Extreme 3.00GHz (QX9650)
Memory: 2048MB (DDR3 APACER 1333 1024M x 2)
HDD: WD SATAII 300 1600AAJS
DVD-ROM: LG DVD-GSA-H55N
– Overclocking capabilities may vary across different cards.
– The 3DMark Vantage scores were obtained using the Extreme Preset.
** To enable Eyefinity technology, a panel with a DisplayPort connector and Windows Vista or Windows 7 are required.
Specifications are subject to change without notice.
PCB color and bundled software versions are subject to change without notice.
Brand and product names mentioned are trademarks of their respective companies.
