The Astell&Kern UW100 TWS Earphones are Category Disruptors
New $299 TWS earphones from Astell&Kern feature a custom DAC with Knowles Balanced Armature Drivers for audiophile-grade performance.
Woman wearing Astell&Kern UW100 TWS Earphones
There are so many new TWS earphones released each month, it is understandable why most people don’t pay attention to them. They have almost become a commodity at this point and it takes a lot to make a splash. The Astell&Kern UW100 TWS Earphones might be a really strong exception to the rule and we’re rather impressed with the price.
The company is better known for its high-end DAPs, but it now offers a line of IEMs ranging from $349 to $3,499. That’s a rather large range but we like where the UW100 are situated in the lineup.
Priced at $299, the Astell&Kern UW100 feature proprietary audio technology that aim to set it apart from the competition. Most True Wireless Stereo (TWS) products available today use a generic Digital to Audio Converter (DAC) built into the Bluetooth module, focusing on lower power consumption rather than better sound quality.
In the UW1000, Astell&Kern combines the unique amplifier and audio circuit technology developed for A&K’s digital audio players with an AKM AK4332 32-bit DAC, which claims to be able to reproduce sound on a whole new level compared to the BT-chipset-integrated DAC.
The UW100 enables clearer and more accurate sound reproduction in all music genres by adopting Knowles Balanced Armature Drivers, which are typically used in expensive IEM systems, instead of the Dynamic Drivers that are common in generic TWS systems.
Internal parts of Astell&Kern UW100 TWS Earphones
DAC Diagram for Astell&Kern UW100 TWS Earphones
Passive Noise Isolation
The Astell&Kern UW100 uses best-in-class Passive Noise Isolation (PNI) to immerse you completely in the music.  Implemented correctly, passive noise isolation is sufficient to reduce noise physically.
Unlike generic ANC, which concentrates on cancelling low-frequency noise, PNI can efficiently cancel unwanted ambient noise in the mid and high ranges, as well as higher-pitched sounds. Notably, the AK UW100’s noise cancelling capability is comparable to that of ANC, even for low frequencies.
A significant feature of passive noise isolation is that sound quality is retained since noise is attenuated by the structure of the earbuds rather than by software in the case of active noise cancellation.
Developed with the help of countless simulations, the AK UW100’s best-in-class PNI capability allows you to escape annoying ambient noise and allows the listener to immerse oneself in an experience where only you and the artist exist.
If the listener wishes to hear ambient sounds, a single tap on the left earbud once activates ambient mode.  You can switch between the four ambient modes by tapping the left earbud or using the AK TWS app.
Astell&Kern UW100 TWS Earphones Inner
Wireless Connectivity
The Astell&Kern UW100 features powerful wireless performance enabled by the premium-tier Qualcomm QCC5141 Bluetooth chipset. The UW100 includes support for aptX Adaptive, Qualcomm’s next-generation high-quality codec for wireless 24-bit sound quality and Bluetooth 5.2 support, for better connectivity than other TWS products.
With the aptX Adaptive codec, latency — the downside of Bluetooth audio — has been significantly improved; aptX Adaptive also provides a feature that adjusts the bit rate according to the content or wireless environment and supports 24-bit audio through a bit rate of up to 420 kbps. In addition, Qualcomm True Wireless Stereo Plus mode minimizes transmission delay by transmitting independent signals to each earbud.
Included ear tips with Astell&Kern UW100 TWS Earphones and Charging Case
With support for USB-C fast charging and wireless charging support, the UW100 can play for one hour with a ten-minute charge. The UW100 provides continuous playback of at least 6 hours and up to 24 hours of playback with the case on a single charge.  Five different sized eartips are included for the best fit.
Calling Features
Featuring two mics per earbud, and incorporating voice communications technology from voice application specialist Alango, the AK UW100 enables quality voice calls.
The UW100 effectively reduces noise in a variety of settings and environments, ensuring call stability using special Acoustic Echo-Canceller and Noise-Suppressor technologies.
Touch controls on each earbud allow a simple tap to switch between functions including play music, answer calls, activate ambient mode, adjust the volume and more.
Touch Controls for Astell&Kern UW100 TWS Earphones
With support for multipoint and multi-pairing, you can pair your UW100 earbuds to multiple devices at the same time.  Not only can you easily switch your connection to another mobile device, but you can also listen to songs played on your tablet, computer, or DAP, while actively allowing phone notifications and calls from your smartphone. The Multi-Point function supports a connection of up to two devices.
The AK TWS companion app, available for iOS and Android devices, allows the listener to customize the touch controls, ambient levels, various EQ settings, and more.
Price & Availability
The Astell&Kern UW100 will be April 11, 2022 at authorized Astell&Kern dealers in the US and Canada for $299.  Pre-orders begin Monday, March 28, 2022.
For more information: us.astellnkern.com
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Shanling’s M3 Plus, iBasso’s DX340, and Astell&Kern’s SP4000 show why DAPs still matter: better power, better sound, and a distraction-free experience no smartphone with...
The Astell&Kern A&ultima SP3000T was the only portable DAP that impressed us in 2024, but it will cost you $2,999 USD.
The British audio company just introduced two totally redesigned in-ear ANC TWS earphones that audiophiles are sure to get excited about.
Astell&Kern ends 2025 with the new AK HC5 USB DAC featuring the AK4499EX and the STELLA reference IEMs developed with VOLK Audio and Michael...
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
DAPs
Astell&Kern PD10 Black DAP ($2,410) gets SP4000 upgrades including bit-perfect Android, Advanced DAR, Smart Gain and Qobuz Connect because color alone won’t cut it.
