DAPs
Astell&Kern Unveils A&norma SR35 DAP
The new Astell&Kern SR35 portable digital audio player is affordably priced at $799, rivaling DAPs from FiiO and Sony.
Astell&Kern SR35 DAPs Lifestyle
The high-end DAP category continues to push back against some strong headwinds. Sony and FiiO have already introduced new entry-level and reference DAPs and Astell&Kern today introduced the A&norma SR35 high-resolution DAP (digital audio player) for $799. It replaces the SR25 MK II portable audio player released in 2021, offering important upgrades for nearly the same price.
Key Features
  • Quad-DAC (Quad/Dual Switching Mode)
  • New Generation AMP Technology
  • 2-Step Gain Mode
  • NEW UI/UX – Crimson Theme
  • Dual Wi-Fi (2.4 & 5 GHz)
  • 20-hour continuous playtime
  • Supports two-way Bluetooth and LDAC, aptX™ HD
  • Roon Ready (First in A&norma series)
Astell&Kern SR35 DAP Front and Back
Quad DAC with Quad/Dual Switching Mode
Like the popular SR25 MK II, the SR35 incorporates Cirrus Logic’s 43198 MasterClass DACs, but adds four of them. A Dual/Quad DAC switching mode is offered enabling users to adjust and improve power management efficiency by allowing the ability to switch between using two DACs or all four DACs during playback, to provide longer continuous playtime time on a single charge.  In dual-DAC mode, the SR35 supports up to 20 hours of continuous playback on a single charge.
2-Step Gain Mode
A 2-step gain level mode allows listeners to create the perfect match for a wide range of headphones and IEMs, maintaining optimal sound output.  The two-step gain setting with “Normal Gain” and “High Gain” modes can generate a high current output to create a powerful sound and excellent driver control.  With up to 6Vrms from the balanced connections, driving high-impedance headphones has never been easier.
Astell&Kern SR35 DAP Flat Angle
Usability
First introduced on the flagship A&ultima SP3000, the SR35 features Astell&Kern’s newly developed 4th generation UX/UI which focuses on the process and experience of listening to music.
The new theme is designed with a focus on the experience of rediscovering songs that you have forgotten; you can quickly browse through music categories with simple gestures. A convenient search feature along with album art has been added so that you can enjoy a digital display of CD album covers of your music collection. It is designed to give you not only the pleasure of listening to music, but also to create fun when operating the device.
With the new crimson theme, one of the main features of the 4th generation UI, the graphics are simple and unintrusive, focusing on usability and intuitiveness. Three key concepts, Edge, Simple, and Dark Mode, were used to improve usability and increase clarity with a style unique to AK. The black and red theme colors are chosen to reduce eye fatigue, maximize battery usage and reduce heat generation.
Astell&Kern SR35 DAP Corner
A new design of audio circuit has been implemented, incorporating Astell&Kern’s unique technologies along with the Quad DAC and our patented TERATON ALPHA technology for outstanding advancement in the dynamics, sense of space, resolution, and level of separation.
The new generation AMP technology applied to the SR35 is Astell&Kern’s unique amplifier design that effectively improves noise reduction at high power output.  With this new technology, the SR35 contains the same amplifier design as the latest A&ultima and A&futura products, completely transforming into an amplifier design worthy of premium audio, from OPAMP selection to component placement and circuit design.
With this new design incorporated in the entry-level SR35, the player boasts a dramatically improved and industry leading SNR of 130dB.
Dual Band Wi-Fi
A first for the A&norma line, the SR35 offers Dual Band Wi-Fi (2.4/5 GHz), providing enhanced wireless network performance to enjoy Hi-Fi music through various streaming and Roon Ready services.
Roon Ready
Roon Ready is a service for Hi-Fi fans who wish to play the best Hi-Fi sound without compromise on various devices through network systems.  Roon Ready, available on some premium audio products, now comes to A&norma series for the first time, offering you a SR35-controlled network audio system to deliver the best sound quality. With the addition of the SR35, Astell&Kern now has 15 Roon certified products available.
Additional features first introduced in the SR25/SR25 MK II that have been included in the new SR35:
  • ReplayGain, which allows the player to automatically adjust the volume between tracks and maintain a consistent playback level.
  • BT Sink two-way Bluetooth, allows the SR35 to connect to an external device via Bluetooth, and function as a Bluetooth DAC. Music from an external device, such as a smartphone can now be played back in high-quality, taking full advantage of the hi-res audio decoding in the SR35.
  • AK File Drop makes transferring music files from a computer or NAS easier and more convenient.  Using AK File Drop, you can freely transfer files wirelessly through a PC, smartphone, or FTP program located on the same network.  Music file management is now possible with a cableless, wireless solution.
  • Users can wirelessly stream 24-bit hi-res audio to compatible speakers, headphones or IEMs with support for LDAC and aptX HD Bluetooth codecs.
  • Native playback of DSD256 and 32-bit/384KHz PCM high-resolution audio
Astell&Kern SR35 DAP Front and Back Angled
Other features include a 3.6-inch 720×1280 HD touchscreen, 64GB of internal memory with support for microSD cards up to 1TB, DLNA networking, USB digital audio output, and the ability to use the SR35 as a USB DAC for your Mac or Windows-based PC.
The SR35 supports MQA, and with a full decoder built in, can unfold all the way to the original resolution of the file.  MQA playback is supported both via downloaded MQA audio files and through the Tidal app, allowing users to stream high resolution audio via Tidal Masters.
Music streaming services including Qobuz, Tidal, Apple Music, Amazon Music, Spotify, and more are also available on the player.  Offline content for supported apps can be stored in either internal or external player memory so you can listen to your favorite music streaming service tracks on the go.
The Astell&Kern A&norma SR35 digital audio player is available as of May 2023 for $799 at headphones.com.
Related reading: Astell&Kern’s AURA IEMs Utilize 11 Drivers
4 Comments
4 Comments
  1. ORT
    April 6, 2023 at 2:55 pm
    A&K present the A&Norma…Abby Norma. It makes one pay for MQA and so the name should represent that abnormality.
    ORT aka Don QuixORTe’
    • Ian White
      April 7, 2023 at 2:27 pm
      ORT,
      You didn’t get the memo about MQA?
      Yes…they put an abnormal codec in a DAP.
      Dr. Frankenstein
  2. Rick
    April 7, 2023 at 8:36 pm
    I don’t think $800 is affordable. $399 is affordable.
  3. ORT
    April 8, 2023 at 6:23 am
    Ian…Yes I got it but as you might expect I spent the last 22.49493 hours in riotous celebration. All those days spent dressed like a Polish babusha and poking pins in that Voodoo Doll that looked like…Well, you know who. Paid off, huh?
    In that 22.48493 hours I equaled my single day record for consuming Monster Energy Drinks. 16 of them. Of course this is why I am still awake…
    Say g’nite, ORT!
    Goodnight ORT.
    El ORTO Verde
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
DAPs
The FiiO JM21 portable digital audio player supports high-quality music playback at an extremely low price.
The Astell&Kern A&ultima SP3000T was the only portable DAP that impressed us this year, but it will cost you $2,999 USD.
Play tapes on-the-go with FiiO's $99 transparent portable audio cassette player with USB-C charging and 13 hour battery life.
DAPs
At $2,999, Astell&Kerns's A&Ultima SP3000T DAP offers a triple amp system with tubes that are easy to get used to.
Bring function, style and entertainment to any educational experience with tech that kids will absolutely love.
