Arylic LP100 Music Streamer Arrives Swinging at the WiiM Ultra: But Can It Really Compete?
At $399, Arylic’s LP100 digital music streamer targets the WiiM Ultra with extra features including AirPlay 2, a built-in MC/MM phono stage, and extensive codec support, offering a flexible alternative for analog and iOS users.
Arylic LP100 Digital Music Streamer Angle
Adding streaming to an older stereo or home theater system has never been easier, and the price of entry keeps sliding downward. You can go full-tilt with high-end, component-size streamers like the Eversolo DMP-A10 ($3,680) or Shanling SM1.3 ($1,199), or keep things simple with compact options like the WiiM Mini ($99), Bluesound Node ($549), Andover Songbird ($199), or iFi Zen Stream ($399). The newest contender crashing the party is the Arylic LP100 ($399) — a surprisingly feature-packed streamer with both wired and wireless connectivity, the ability to slot into an existing setup, and even direct support for powered speakers if you want a minimalist system.
At its price, the Arylic isn’t gunning for the heavyweights; its real target is the WiiM Ultra ($329) and every other “do-it-all without draining the bank account” streamer trying to win the living-room throne.
What the Arylic LP100 Brings to the Table
arylic-lp100-dimensions
The LP100 keeps things visually simple with a compact, minimalist chassis — no front-panel display, no flashy distractions, and roughly half the footprint of a typical stereo or AV receiver. The understatement ends there. Inside, Arylic has loaded this streamer with genuinely serious hardware. At its core are the AKM AK4499SEQ DAC, AK7735 ADC, and CT7302SL sample-rate converter, a trio designed to handle high-resolution playback and clean signal processing with far more precision than you’d expect at this price.
On the network side, Arylic future-proofs the LP100 with Wi-Fi 6E support and Gigabit Ethernet, giving you a stable, high-bandwidth connection for lossless streaming regardless of where it sits in your system.
The LP100 checks off the major streaming essentials with Spotify Connect and TIDAL Connect, and it goes a step further by arriving fully Roon Ready—a box many streamers in this price tier still can’t tick.
Wireless flexibility is another strong point. Arylic includes Bluetooth 5.4 with both transmit and receive capability, along with a full suite of modern codecs: LDAC, SBC, aptX Adaptive, aptX Low Latency, aptX HD, and even Auracast for broader broadcast-style sharing. If you prefer platform-native streaming, Apple AirPlay 2 and Google Cast are on board as well.
For local playback, the LP100 accepts flash drives via its USB input, and it can operate as a DLNA-compatible music hub, giving you multiple paths to feed your system without needing a dedicated server.
Physical connectivity is equally straightforward and surprisingly complete. The LP100 offers optical and coaxial digital inputs, plus RCA analog outputs for feeding an external amplifier or powered speakers. There’s also HDMI eARC, giving you a clean path to pull audio directly from your TV without juggling extra boxes.
A rare perk at this price: the LP100 includes a MM/MC-compatible phono input, letting you plug in a turntable without needing a separate phono preamp. It’s an unexpected but very welcome nod to vinyl listeners who want a single box handling both streaming and analog playback.
Control is equally flexible. The LP100 includes an onboard rotary knob for quick adjustments, full app control for deeper navigation, and voice control support if you want hands-free operation. Arylic also ships a BLE remote in the box, and for those who prefer a more premium interface, there’s an optional Lifestyle Remote available separately.
Comparison
arylic-lp100-wiim-ultra-streamers
Arylic LP100WiiM Ultra
Product Type Music Streamer Music Streamer
Price$399$329
WiFiIEEE802.11 b/g/n 2.4GHz, 5GHz6E
Ethernet/LAN10/100M RJ45Yes
Bluetooth5.45.3
Bluetooth Transmit Codec SupportSBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, LC3
1x Bluetooth TX, able to connect up to 1 Bluetooth speaker or headphones
SBC, AAC, LC3, Bluetooth LE Audio
Bluetooth Receive Codec SupportSBC, AAC, aptX, aptX HD, aptX AD, LDAC, LC3
2x Bluetooth RX, able to connect up to 2 smartphones
BroadcastAuracast, 10mAuracast, 10m
Streaming ProtocolsWiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready (via update), DLNA, UPnPWiFi, Google Cast, Spotify Connect, Tidal Connect, Qobuz Connect, Roon Ready, DLNA, UPnP
Frequency Response20Hz – 20kHz ±1 dB20Hz – 20kHz ±0.5dB
THD+N≤0.001 %-116 dB (0.00015%)
SNR≥80 dB121 dB
Crosstalk≥80 dBNot Indicated
DACAKM AK4493SEQESS ES9038Q2M
ADCAKM7735TI PCM1863
SRCCT7302SLNot Indicated
Wired InputsRCA x 1
Phono (MM/MC) x 1
Optical x 1
HDMI eARC x 1
USB Host x 1
Coaxial In x 1
USB-B DAC x 1 (for PC connection)
RCA  x 1
Phono (MM)  x 1
Optical x 1
HDMI ARC x 1
USB Host x 1
Wired Audio OutputsRCA  x 1
Optical x 1
Subwoofer x 1
RCA x 1
Optical x 1
Subwoofer x 1
Coax x 1
USB x 1
Headphone x 1
Room CorrectionNoYes
Front Panel DisplayNoYes
Control Rotary Knob (Switch between modes, volume, and power)
Touch Buttons (Play/pause, skip tracks, and Auracast)
Reset Button (Repair WiFi/Bluetooth, restore to factory settings)
Go Control App
Siri, Google Assistant
BLE remote control
Lifestyle remote (optional)
Voice Remote 2
Voice Control
Alexa, Google Assistant
WiiM Home app
Power InputUSB Type-C Port 5V/2A100-240V AC input, 50/60 Hz, 0.5A Max
Dimensions6.57 x 6.57 x 1.71 inches
167 x 167 x 43.5 mm
8.3 x 7.87  x 2.83 inches
211 x 200 x 72 mm
Weight550 g / 1.23 lbs1.42 kg / 3.13 lbs
Trigger Out12V12V
Package ContentsLP100 x 1
BLE Remote Controller x 1
Manual x 1
5V/2A Power Adaptor x 1
2-2 RCA Cable x 1
USB Type-C Power Cable x 1
USB Type-B Data Cable x 1
WiiM Ultra x 1
Remote Control x 1
Manual x 1
Power Cable x 1
RCA Cable x 1
HDMI Cable x 1
Optical Cable x 1
Phono Ground Adapter x 1
arylic-lp100-with-bk01-remote
Arylic LP100 with optional BK01 Lifestyle Remote
The Bottom Line
The LP100 is clearly Arylic’s attempt to take a swing at the WiiM Ultra, offering a similar “do-everything in one box” approach but with its own twist. While both units aim for the same customer—someone who wants a modern, highly capable streamer without writing a four-figure check—the LP100 makes its case with features the Ultra simply doesn’t include.
The built-in MM/MC phono stage immediately stands out, giving vinyl listeners a direct, clutter-free path into a system without adding another box. AirPlay 2 is another major difference, especially for iOS users who dismissed the WiiM Ultra for skipping it. Add Bluetooth 5.4 with transmit and receive capability, a full codec suite, DLNA compatibility, USB playback, and a strong AKM-based DAC section, and the LP100 comes across as the more analog-and-codec-friendly option.
The flip side is where the WiiM Ultra digs in. WiiM continues to offer one of the best control apps in the streaming category—beating not just its direct rivals but embarrassing some higher-priced gear as well. The Ultra’s front-panel display, wired headphone output, room correction, and native Qobuz Connect give it advantages that matter for anyone who wants deeper system control, visual feedback, or direct integration with their preferred streaming service.
Those omissions on the Arylic side might be deal-breakers for some. And outside the Ultra matchup, the LP100 also competes indirectly with the WiiM Pro Plus, a streamer that remains a favorite for its balance of features, price, and app quality.
Ultimately, the LP100 is more about flexibility—especially if you want a single box for streaming, Bluetooth, casting, and a turntable. The WiiM Ultra focuses on refinement, interface quality, and features that appeal to the modern streaming ecosystem. Both have their strengths, but the better choice depends on whether your system and listening habits lean more toward analog versatility or a polished, app-driven streaming experience.
arylic-lp100-angle
Price & Availability
The Arylic LP100 digital music streamer is priced at $399 at Arylic.com. The optional BK01 Lifestyle Remote is an extra $79 at Arylic.
The WiiM Ultra is $329 at Amazon.
Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Can AI earbuds actually improve your workday? Viaim Rise records meetings, creates notes, and helps turn conversations into actionable tasks.
Can open-back headphones work as everyday wireless cans? Audio-Technica’s ATH-AL5NC add LDAC, ANC, wired playback and up to 75 hours of battery life.
Bluesound NODE review: Can the $750 streamer outclass WiiM and Cambridge with improved sound, stable BluOS, and Dirac Live potential?
SOUNDPEATS Air5 Pro+ adds xMEMS drivers, AI Adaptive ANC, LDAC, and aptX Lossless, delivering a true 2-way design and hi-res performance at a budget-friendly...
Dutch & Dutch’s new 6c wireless speaker brings compact design, BACCH3D audio, RoomMatching, and high-end engineering to a smaller, more flexible footprint.
Bowers & Wilkins brings its McLaren partnership back for 2025 with the Px8 S2 McLaren Edition, pairing the updated S2 acoustic platform with clean...
