DAPs
Archos Vision A15VS Portable MP3 Player
The ARCHOS Vision A15VS is incredibly thin and light with a highly responsive touch screen that makes using the A15VS simple and intuitive. Featuring 1.5” colour screen and 4 GB storage the A15VS can store up to 2,000 songs in the most popular formats (MP3, WAV, FALC, APE and WMA), along with photos and short video clips.
The built-in FM Radio allows you to listen to your favourite stations and also packs in an audio recorder allowing you to make recordings direct from FM radio or via the built in microphone.
Available this spring.
MSRP: £34.99. (check price)
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
