Arcam airDAC Wireless DAC
Arcam airDAC
Delayed since last year due to AirPlay component shortages, the Arcam airDAC is being relaunched in April 2014 with markedly increased functionality and a new free SongBook UPnP Control App. Arcam claims its airDAC is the only audiophile-grade Airplay product in existence and now features UPnP Streaming, plus two secondary digital audio inputs. It has high-class analogue outputs plus an SPDIF output that can be connected to a reference quality DAC like the Arcam FMJ D33.
Arcam’s Songbook app is a UPnP music player that can be downloaded FREE from the Apple App Store to use with the airDAC.  Android & PC users can use a number of UPnP music players such as PlugPlayer and Bubble. UPnP can play lossless files up to 24bit / 96kHz resolution (currently AirPlay is restricted to playing Apple Lossless files up to 16bit / 48kHz). These can be streamed via UPnP to the airDAC from any computer, NAS drive or Music Server running a UPnP server
AirPlay with iDevices running iOS 7, can send send music to a Hi-Fi/AV system from Internet radio services like vTuner and TuneIn Radio, as well as music streaming services like Spotify and Qobuz.
The airDAC is said to use the finest quality parts in a layout that is optimized for low noise and distortion. A dejittering design that Arcam have used in many of the reference class FMJ products is applied to all inputs. The four-layer PCB allows our designers to maximise the quality of the ground plane in order to further reduce interference between components. The use of multiple low noise separately regulated power supplies ensures that we get the cleanest signal to the audiophile quality output stage.
Arcam airDAC back
The airDAC’s WiFi is compatible with 802.11 b/g/n but it also hosts a wired Ethernet (RJ45) connector for the most reliable results from any network. The elegant cast-alloy case, reduces microphone effects and has a non-slip rubber base.
Price and Availaibility
The Arcam airDAC is available April 2014 for £400 / $700.
Arcam Songbook iPhone appSpecifications
  • DAC – TI PCM5102
  • Input – Airplay / UPnP, SPDIF/Optical
  • Frequency response – 10Hz — 20kHz, ±0.1dB
  • Total Harmonic Distortion + Noise – 0.002%
  • Signal-to-noise ratio (A –Weighted) – 106dB (24-bit)
  • Line output level – 2.15Vrms
  • Supported sample rates – 44.1kHz, 48kHz, 88.2kHz, 96kHz
  • Bit depth – 16-bit, 24-bit
  • Power requirements – 7W max
  • Dimensions (wxdxh, mm) – 190 x 120 x 44
  • Weight – 1.1kg
Features
  • Add Airplay & UPnP streaming to any Hi-Fi or AV system
  • SPDIF and optical digital inputs for additional components
  • 24 bit / 192 kHz High-Performance DACs
  • Class leading high-end analogue line-level output
  • SPDIF output to feed higher-end DACs such as Arcam irDAC and FMJ D33
  • High-end audiophile-grade circuitry and components throughout
  • Stylish cast aluminium case with damped rubber base
  • Advanced graphical SongBook iPad/iPhone control app (Free)
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
