Desktop PC
Apple Previews New Mac Pro Desktop
Apple Mac Pro 2013
Apple today unveiled their next generation Mac Pro desktop computer that is crafted in a unique cylindrical design, just 9.9-inches tall and 6.6-inches in diameter. It is packed with an evolutionary unified thermal core, next generation Xeon processors, dual workstation-class GPUs, Thunderbolt 2, PCIe-based flash storage, and ultra-fast ECC memory.
The new Mac Pro’s ingenious unified thermal core allows the desktop to efficiently share its entire thermal capacity across all the processors. The result is a pro desktop with breakthrough performance packed into a design that is one-eighth the volume of the current Mac Pro. Next generation Intel Xeon E5 processors with up to 12 core configurations deliver double the floating point performance. With two AMD FirePro workstation-class GPUs, the all-new Mac Pro is up to 2.5 times faster than the current Mac Pro and delivers up to an amazing 7 teraflops of compute power. The new Mac Pro also features PCIe-based flash storage that is up to 10 times faster than conventional desktop hard drives and includes the latest four-channel ECC DDR3 memory running at 1866 MHz to deliver up to 60GBps of memory bandwidth. With all that power, the new Mac Pro lets you seamlessly edit full-resolution 4K video while simultaneously rendering effects in the background.
Apple Mac Pro 2013 - back
The next generation Mac Pro is the most expandable Mac ever built. With six Thunderbolt 2 ports that can deliver up to 20Gbps of bandwidth to each external device, Mac Pro is perfect for connecting to external storage, multiple PCI expansion chassis, audio and video breakout boxes, and the latest external displays, including 4K desktop displays. Each of the six Thunderbolt 2 ports supports up to six daisy-chained devices, giving you the ability to connect up to 36 high-performance peripherals. Thunderbolt 2 is completely backwards compatible with existing Thunderbolt peripherals, and allows you to transfer data between Macs faster and easier than ever.
Price and Availability
The next generation Apple Mac Pro will be available later this year (2013) in black. Pricing TBD. To learn more, visit www.apple.com/mac-pro.
Apple Mac Pro 2013 - front
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
