Aperion erects sleek power towers at HE Show
Elegant solution for listeners constrained by space or their own aesthetics
http://www.aperionaudio.com
NEW YORK CITY (May 20, 2004)–Aperion Audio’s new Intimus Power Tower speaker (522D-PT) is a full range speaker that merges the lush imaging of the acclaimed Intimus bookshelf speaker with the full-bodied bass response of a powered subwoofer built into the base of the tower.
“It’s a complete audio solution for someone with space constraints–like a New York apartment–or who just wants to hear more and see less,” says Aperion CEO Winthrop Jeanfreau.
Designed for both home theater and music applications, the full range speaker is engineered with the ideal crossover frequency and slope for the sub to create a seamless blend between the subwoofer, midrange and tweeter.
The power tower is also outfitted with the patented DiAural Crossover for immense sound staging and crystal clear imaging. The result is exquisite detail, coherent blending, total harmonic integrity and smooth frequency response from 30Hz to 20kHz.
The 5.25″ midrange and 1″ tweeter are both powered by you’re A/V receiver while the built-in 150-watt amplifier powers the 8″ sub. The dual subwoofers make placement and setup a no-brainer. This integrated solution gives listeners the choice to eliminate a stand-alone sub or to add another sub to wake the neighbors on the next block.
Aperion speakers, consistently lauded for remarkable quality in their price category, are constructed with rock solid 1” thick high-density fiberboard with a furniture-grade real cherry wood or high gloss black painted finish.
Aperion Audio manufactures and sells speakers directly, online with a risk-free, 30-day audition. Aperion is setting a new standard for customer service, online or off, with smart audio information resources and unmatched customer support before, after–or regardless of–a purchase.
~ thank you ~
Contact: John Wanderscheid
Toll free 888-880-8992
john.wanderscheid@aperionaudio.com
