Aperion Audio Verus II Grand Floorstanding Loudpseakers Announced
Aperion Audio Verus II Grand Tower Speakers with grille
Aperion Audio just announced their newest flagship floorstanding loudspeakers called Verus Grand II Tower that continue the company’s tradition of offering audiophile sound quality at a budget price point. These 65 lbs behemoths stand almost 4-feet tall and replace the original (same sized) Verus Grand speakers first introduced in 2011, but offer a few key upgrades.
The Aperion Audio Verus II Grand Tower speakers get an entirely redesigned crossover network. The company says the new crossover lends to a more neutral and better balanced frequency response along with smoother phase integration across drivers. Aperion has also upgraded internal connectivity with larger gauge wiring to the tweeter, midrange, and woofer drivers. On the exterior, the company replaced stamped metal jumpers between speaker binding posts in favor of high quality 12-guage wire jumpers.
Verus II Grand Tower also comes with a completely refined version of Aperion’s proprietary in-house tweeter. The new patented Axially Stabilized Radiator (ASR) tweeter retains the anchored center point of the original ASR design while adding a new wishbone waveguide. Aperion says its new ASR has a more uniform high-end frequency response and offers broader dispersion across a listening area.
Each floorstanding speaker weighs 65 lbs. and is 43.5-inches tall. It features one tweeter, two 5-inch woven Kevlar woofers, two 6-inch woven Kevlar woofers. Sensitivity is measured at 92dB and can play 45 Hz to 20 kHz, +/- 3dB.
Features
1. New Patented Axially Stabilized Radiator Tweeter
Patented Axially Stabilized Radiating tweeter retain the anchored center point of the original ASR tweeter to better control break up modes. Additional design refinements coupled with the new “wishbone” waveguide produces better output, more uniform frequency response and broader dispersion across its operating range.
2. Redesigned Crossover Network
Fine-tuning of the crossover networks has resulted in a smoother, more neutral and better balanced frequency response across the entire audible range. You’ll experience better phase integration between the tweeter and midrange drivers resulting in a cleaner, more open sound in the transition regions.
3. Larger Gauge Internal Wiring
Upgraded wiring from 18 gauge to 16, 14 and 12 gauge wiring supporting the tweeter, midrange and woofer respectively. The outcome is more “headroom” in higher power applications.
4. High Quality 12 Gauge Jumpers
The stamped metal jumpers have been replaced with 12-gauge wire jumpers between the binding posts creating more surface area for signal flow. This results in lower resistance, lower impedance and overall better transfer of signal at the speaker’s terminals.
Price and Availability
The first shipments are expected to arrive late January early February 2016 for about $2,500/pair in glossy piano black or cherry finishes.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Loudspeakers
Our hi-fi show coverage of T.H.E. Show SoCal 2024 includes stereo systems ranging from a few hundred dollars to over $500K.
Aperion Audio, a consumer direct maker of award-winning home theater speaker systems, has added their first ever outdoor speaker. The Aperion Intimus Outdoor Speaker...
Aperion erects sleek power towers at HE Show Elegant solution for listeners constrained by space or their own aesthetics http://www.aperionaudio.com NEW YORK CITY (May...
Loudspeakers
New center channel speaker stands up and sings Aperion’s vertical array solution debuts at NYC H.E. Show www.aperionaudio.com NEW YORK CITY (May 20, 2004)–...
Are you ready to invest in your first home theater system and don’t have a lot of cash? Then seriously consider an Aperion Audio...
Loudspeakers
Provides the Option To Match Surround Sound Format According To Preference Aperion Audio, the first company to provide a totally risk-free buying experience, today...
Aperion Audio Announces A New Voice New HD-X3 Crossover Technology Optimizes Award-Winning Performance NEW YORK, NY – April 28, 2005 – Aperion Audio, the...
Loudspeakers
Aperion Audio Announces The Newly Voiced Intimus 5-Series Speaker Line Raising the Bar On It’s Award-Winning Mid-Sized Speakers NEW YORK, NY – April 28,...
