Aperion Audio Verus Grand Home Theater Speaker System
Aperion Audio today announced the Aperion Verus Grand line of home theater speakers, with a patent-pending tweeter, for authentic sound reproduction. Aperion built the entire speaker system from the bottom up, engineering each component for maximum sonic impact while keeping the cost in reach of most home theater audio buffs. True-to-life sound sparks an emotional connection that transports movie and music lovers into the performance, exactly as the producers intended.
“The goal for the Aperion Verus Grand line was to create an accurate, uncolored, lifelike experience,” says Ken Humphreys, Aperion's lead speaker engineer and a 25-year-veteran of speaker system and component design for the audio industry's most respected brands. “To do that, our team built the entire speaker system from the bottom up, engineering each component for maximum sonic impact while keeping the cost in reach of most home theater audio buffs.”
“A key part of the solution is our new Axially Stabilized Radiator tweeter, which takes the burden of reproducing upper-mid frequencies off the mid-range driver,” Humphreys adds. “That allows each driver to do the job it does best. The result is wider dispersion for an expanded soundstage and lower distortion to boost clarity.”
The audio enthusiast can configure a well-matched high-performance 5.0 home theater system by combining a pair of tower speakers, a center channel and a pair of bookshelf speakers for surrounds, all from the Aperion Verus Grand family. An enhanced 5.1 system is attained simply by adding an Aperion Bravus subwoofer. In addition to filling a room with sound, the Aperion Verus Grand family's curved cabinets in gloss cherry-wood veneer or piano-black lacquer lend elegance to any decor.
Aperion Audio Verus Grand Center Channel Speakers
Aperion Verus Grand Center
The Verus Grand Center Channel speaker provides an enhanced vertical array design, which casts a wide net of sound (aka dispersion), ensuring that every seat in the house is perfect. The incredible sonic clarity of our new Aperion ARS tweeter paired up with our 4″ woven Kevlar mid-range speaker faithfully reproduces the voices in your movies and music, and the lows are handled dynamically by two new proprietary 6″ woofers. All These components fit gracefully into a beautifully curved cabinet, with hidden rubber feet that let you angle the speaker to your sweet spot. The Verus Grand Center channel speaker is available finished in furniture-grade gloss cherry-wood veneer or piano-black lacquer.
Key Features of the Aperion Verus Grand Center
  • 3-Way, Sealed Enclosure design
  • One 1″ Aperion Axially Stabilized Radiator silk dome tweeter
  • One 4″ Woven Kevlar® Mid-range driver with Aluminum Phase Plug
  • Two 6″ Woven Kevlar® Woofers with Butyl Rubber Surrounds
  • Curvilinear cabinet with compound angles and internal bracing
  • Furniture-grade gloss cherry wood veneer or gloss piano black finish
  • VoiceRight phase correction switch for bass optimization
  • 5-Way Gold-plated Binding Posts
  • Acoustically transparent cloth -covered metal grille
Aperion Audio Verus Grand Bookshelf Speakers
Aperion Verus Grand Bookshelf
The new Verus Grand Bookshelf speaker represents truly huge sound in a small package. Aperion has taken the sonic design and cabinet of the Verus Grand Tower speaker and condensed it for use as front speakers in a small home theater, or as surround speakers in a larger home entertainment center. It uses our patent-pending ASR tweeter to bring in the high frequencies, and our brand new 5″ midrange driver with aluminum phase plug to round out the sound.
Key Features of the Aperion Verus Grand Bookshelf
  • 1-inch Aperion Axially Stabilized Radiator silk dome tweeter
  • One 5-inch woven Kevlar® mid-range drivers with aluminum phase plug
  • 2-way bass reflex design
  • 5-way gold-plated binding posts
  • Beautiful curved cabinet with compound angles and internal bracing
  • Acoustically transparent, magnetically held, cloth-covered metal grille
Aperion Verus Grand Tower
The Aperion Verus Grand Tower loudspeaker is their top-of-the-line model. It delivers an amazingly lifelike, natural sound with a flat frequency response, delivering octaves of pure listening pleasure. The Verus Grand Tower's four proprietary woven Kevlar® woofers and mid-range drivers are uniquely combined with our new patent-pending Axially Stabilized Resonator tweeter. This matching results in gorgeous sonic performance from the lowest low to the highest high, for a truly enveloping musical sound.
Aperion Audio Verus Grand Tower Speakers
Key Features of the Aperion Verus Grand Tower
  • 3-way, bass reflex design
  • Two 5-inch woven Kevlar® mid-range drivers with aluminum phase plugs
  • Two 6-inch woven Kevlar® woofers with butyl rubber surrounds
  • Bi-ampable 5-way gold-plated binding posts
  • Acoustically transparent cloth-covered metal grille
Specifications of the Aperion Verus Grand Tower
  • Frequency response: (+/- 3 dB) 45-20,000 Hz; (+/- 6 dB) 35-22,000 Hz
  • Nominal impedance: 6 ohms
  • Sensitivity: 92 dB
  • Recommended power: 20-300 watts
  • Driver configuration: 3-way
  • Bass alignment: bass reflex (dual port)
  • Dimensions: 43.5 inches high by 8 inches wide by 12 inches deep
  • Weight: 65 pounds
Pricing, Availability and Warranty:
Pricing for the new Aperion Verus Grand line of home theater speakers is $1,798 per pair for the Verus Grand Tower; $699 for the Verus Grand Center; and $598 per pair for the Verus Grand Bookshelf. Pre-orders are now being accepted, and the system will ship on October 30, 2010. A 10-year limited warranty covers all defects in material and workmanship.
Aperion Audio Verus Grand Speakers - Tweeter detail
Aperion Audio Verus Grand Speakers - Woofer detail
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Loudspeakers
Our hi-fi show coverage of T.H.E. Show SoCal 2024 includes stereo systems ranging from a few hundred dollars to over $500K.
Aperion Audio, a consumer direct maker of award-winning home theater speaker systems, has added their first ever outdoor speaker. The Aperion Intimus Outdoor Speaker...
Aperion erects sleek power towers at HE Show Elegant solution for listeners constrained by space or their own aesthetics http://www.aperionaudio.com NEW YORK CITY (May...
Loudspeakers
New center channel speaker stands up and sings Aperion’s vertical array solution debuts at NYC H.E. Show www.aperionaudio.com NEW YORK CITY (May 20, 2004)–...
Are you ready to invest in your first home theater system and don’t have a lot of cash? Then seriously consider an Aperion Audio...
Loudspeakers
Provides the Option To Match Surround Sound Format According To Preference Aperion Audio, the first company to provide a totally risk-free buying experience, today...
Aperion Audio Announces A New Voice New HD-X3 Crossover Technology Optimizes Award-Winning Performance NEW YORK, NY – April 28, 2005 – Aperion Audio, the...
Loudspeakers
Aperion Audio Announces The Newly Voiced Intimus 5-Series Speaker Line Raising the Bar On It’s Award-Winning Mid-Sized Speakers NEW YORK, NY – April 28,...
