Loudspeakers
Aperion Audio Intimus 4B, 4C, 4T Home Theater Speakers
Aperion Audio updated their Intimus home theater speaker line-up offering better performance at 15-percent lower price points. The updated speakers include the Intimus 4T Tower, Intimus 4C Center and Intimus 4B Satellite.
“Given the recent economy, our design goal for the updated Intimus series was to deliver an even better value to end users without impacting the sonic performance,” says Ken Humphreys, Aperion’s lead speaker engineer and a 25-year-veteran of speaker and component design. “We looked at every element of Intimus to determine what it contributes to the user experience. For example, most home theaters now use LCD or plasma TVs, so we eliminated the magnetic shielding used to prevent speakers from distorting the picture on CRT TVs. We’re also proud of the redesigned base and a cabinet fit and finish that still surpass those for any speaker in this price range.”
To give the Intimus towers a sleeker overall look, Aperion Audio replaced the wooden base with cast aluminum feet. The cabinets are now wrapped in a premium-grade simulated wood finish. An increase in efficiency lets the new speakers achieve the same volume with less power. These small adjustments enable a minimum price drop of 15 percent across the entire Intimus line and a slight boost in performance as well.
Home entertainment enthusiasts can configure an audiophile-grade 5.1 home theater system for under $1,200 by combining a pair of Intimus 4T tower speakers, an Intimus 4C center channel and a pair of Intimus 4B satellite speakers for surrounds, and then underpinning the system with an Aperion Bravus 8A subwoofer. The Intimus 4T tower saves space with an 8-inch-by-8-inch footprint but includes dual 4″ woven-fiberglass woofers and a 1″ silk-dome tweeter in a front-ported enclosure. All Aperion Intimus speaker cabinets feature a curved-edge design and are available in high-quality simulated Medium Cherry or Black Ash.
Key Features of the Aperion Intimus Tower
  • Dual 4″ woven-fiberglass mid-woofers
  • 1″ custom-designed silk-dome tweeter
  • Curved-edge design aesthetic and small footprint
  • Anti-resonant cabinet
  • Premium-quality simulated wood finish
Specifications of the Aperion Intimus 4T Tower
  • Frequency response: (±3 dB) 60-20,000 Hz; (±6 dB) 50-22,000 Hz
  • Nominal impedance: 6 ohms
  • Sensitivity: 88 dB
  • Recommended power: 25-150 watts
  • Driver configuration: 2-way
  • Dimensions: 34 inches high by 5 inches wide by 7.5 inches deep
  • Weight: 19 pounds
Pricing, Availability and Warranty:
The Aperion Intimus line of home theater speakers are available now in cherry finish with ash black models coming November 30, 2011. A 5-year limited warranty covers all defects in material and workmanship.
  • Intimus 4T Tower → $550 per pair
  • Intimus 4C Center → $130 each
  • Intimus 4B Satellite → $220 per pair
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Loudspeakers
Our hi-fi show coverage of T.H.E. Show SoCal 2024 includes stereo systems ranging from a few hundred dollars to over $500K.
Aperion Audio, a consumer direct maker of award-winning home theater speaker systems, has added their first ever outdoor speaker. The Aperion Intimus Outdoor Speaker...
Aperion erects sleek power towers at HE Show Elegant solution for listeners constrained by space or their own aesthetics http://www.aperionaudio.com NEW YORK CITY (May...
Loudspeakers
New center channel speaker stands up and sings Aperion’s vertical array solution debuts at NYC H.E. Show www.aperionaudio.com NEW YORK CITY (May 20, 2004)–...
Are you ready to invest in your first home theater system and don’t have a lot of cash? Then seriously consider an Aperion Audio...
Loudspeakers
Provides the Option To Match Surround Sound Format According To Preference Aperion Audio, the first company to provide a totally risk-free buying experience, today...
Aperion Audio Announces A New Voice New HD-X3 Crossover Technology Optimizes Award-Winning Performance NEW YORK, NY – April 28, 2005 – Aperion Audio, the...
Loudspeakers
Aperion Audio Announces The Newly Voiced Intimus 5-Series Speaker Line Raising the Bar On It’s Award-Winning Mid-Sized Speakers NEW YORK, NY – April 28,...
