Monitors
AOC 27-inch Monitor Recharges Smartphones Without Wires
AOC P2779VC PLS Monitor with Qi Wirless Charging Base
Monitor with Qi Wireless Charging Base De-clutters your Desktop
AOC announced an affordably priced 27-inch 1080p monitor (model P2779VC) with integrated wireless charging base that supports many Android smartphones. Simply place any Qi compatible device on top of the base to automatically begin recharging without any cables. The PC monitor also features wide-viewing angles, HDMI/VGA connections, 8-bit color depth, 5ms response, and matte anti-glare coating.
AOC P2779VC PLS Monitor Side View
Qi Wireless Charging technology comes from the Chinese meaning “natural energy”. The technology is an interface standard developed by the Wireless Power Consortium for inductive electrical power transfer that wirelessly charges a compatible device’s battery using induction transfer. The monitor’s Qi Wireless Charging Base removes the hassle of cables and allows you to keep your device in view while charging and using the display, without having to worry about finding an outlet nearby. Compatible devices include Samsung Galaxy S5-6/Edge, Google Nexus 4-7, Motorola Droid Maxx, and Nokia Lumia 920-1520, among others.
AOC P2779VC PLS Monitor Back View
Additionally, the display’s Plane to Line Switching (PLS) panel gives 178/178 degree viewing angle while maintaining consistent image quality and colors from all viewing positions. This PLS panel has true 8-bit color depth that results in incredible color accuracy and features a matte anti-glare coating that won’t leave fingerprints or smudges. PLS is perfect for graphic designing, video editing and photo retouching. You can also view your spreadsheets or weekend movies from virtually any angle without compromising color uniformity.
The P2779VC features Full HD 1920 x 1080 resolution with 20,000,000:1 contrast ratio for greater color depth and detail. It also boasts a 5ms response time to eliminate drag. On the back, connectivity options include one VGA and two HDMI inputs.
Price and Availability
The AOC 27” PLS Monitor featuring a Qi Wireless Charging Base will be available in the U.S. this month (December 2016) at Amazon, Best Buy, and NewEgg for $249.99 MSRP.
Specifications
Viewable Screen Size 27″
Panel Type PLS Panel
Aspect Ratio 16:9
Brightness 300 cd/m2 (typ)
Contrast Ratio (dcr) 20,000,000:1 (dynamic)
Response Time 5ms (gtg)
Max Resolution 1920 x 1080 @60Hz
Color Depth 16.7 Million colors
Pixel Pitch (mm) (H x V) 0.311 (H) mm x 0.311 (v) mm
View Angle (degrees) (H x V) 178 / 178
Display Area (mm) (H x V) 597.88 mm x 336.31 mm
Cabinet Color Black with Gold Base
Adjustability Tilt: -3.5°±1.5°~+21.5±1.5°
Inputs VGA, 2x HDMI
Power Consumption Power On: <23.5W (Max), Standby: <0.5W
Power Source Universal 110~240VAC, 50/60Hz
User Control Source/Auto/Exit, Clear Vision Volume, Menu/Enter, Power
Regulations cTUVus, CE, FCC, RoHS, EPEAT, Energy Star, Windows 8/10 compatible
OSD Languages 16 Languages including English, French and Spanish
Other Features Qi Wireless charging base, User Friendly Graphical OSD Menu, Kensington Security Slot, Includes AOC’s e-Saver software, i-Menu software
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
