Monitors
AOC i2353Ph Aire Pro LED LCD Monitor
AOC introduced the ultra-slim 23-inch Aire Pro (model i2353Ph) LED-backlit LCD Monitor in a sleek brushed metallic finish. This High Definition 9.2 mm thin monitor features an IPS (In-Plane Switching) panel, a superior type of screen that offers consistent image appearance and colors across the entire display, even from extreme viewing angles. The Aire Pro also offers Dual HDMI, making it easy to connect the monitor directly to your Blu-ray Player or gaming console to watch your favorite movies and TV shows and play video games. Additionally, the monitor includes bonus features like embedded Screen+ software that allows you to divide the screen into four self-contained work areas for added productivity.
The modern widescreen Aire Pro monitor is one of the slimmest display panels on the market and offers impressive image quality with a 50,000,000:1 Dynamic Contrast Ratio, 5ms response time, and twin HDMI ports for the ultimate HD viewing experience. The monitor is also equipped with multiple power-saving features for reduced environmental impact, while the LED backlight is completely Mercury free. An Off Timer allows you to set an alarm clock to turn of the monitor automatically, and the eSaver feature lets you preset power conservation modes for the display when the PC is not in use. The monitor's Power Saving Mode uses 50 percent less power, and Standby Mode uses only 0.1w. The monitor also comes in green packaging.
The Aire Pro has illuminated soft-touch controls on the front of its base and a user-friendly graphical OSD menu that make adjusting settings simple. The base also transforms into a built-in VESA stand that locks into place so that the monitor can be used on a desktop and easily mounted on a wall by simply pushing a button and folding the stand at its tilt hinge. No assembly is required for the stand. The monitor's easily accessible connections are located at the back of the stand.
Specifications
  • Ultra-thin LED IPS Monitor (9.6mm thin)
  • Multiple I/O Ports (2 HDMI)
  • Viewable Image Size: 23″
  • 16:9 Aspect Ratio
  • WLED Backlight
  • Brightness: 250cd/m²
  • 50,000,000:1 DCR
  • 5ms Response Time
  • Two built-in speakers
  • Screen+ Technology
  • e-Saver Feature for low power consumption
  • Eight OSD languages including English, Spanish, French and more
  • iF Design Award winner
Price and Availability
The AOC Aire Pro monitor (i2353Ph) is now available for $199.
See more about: Newest Monitors, LED Monitors, LCD Monitors, AOC Monitors
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
