Monitors
AOC G2460PQU Gaming Monitor
AOC Gaming Monitor
AOC today announced the 24-inch 144Hz Gaming Monitor (G2460PQU) which claims a 1ms response time. Designed for high-performance gaming,  the wall-mountable monitor has a black hairline textured design with a sleek red bar at the bottom bezel, and comes with Display Port, HDMI, DVI-Dual Link, VGA, with four USB 2.0 ports. The USB hub includes a fast-charging port for mobile devices that is three times faster than a standard USB port. Plus the monitor’s four-way adjustable stand allows gamers to change the monitor height by 130mm, swivel left and right, tilt the screen angle, and pivot 90 degrees to landscape or portrait view to maximize the gaming experience.
The AOC 144Hz Gaming Monitor’s 24-inch screen displays up to 16.7 million colors with a maximum resolution of 1920×1080, perfect for HD games and movies. The monitor’s direct-insert, easy-access ports make it simple to connect to USB devices, Blu-ray players, game consoles and more.
The AOC G2460PQU allows you to switch between seven different screen sizes: 17” Pillar Box (5:4), 19” Pillar Box (5:4), 19” Widescreen (16:10), 21.5” Widescreen (16:9), 22” Widescreen (16:10), 23” Widescreen (16:9) and 24” Widescreen (16:9). With these options, the display provides the best possible view for any application or game. The VESA-compatible monitor can also be unscrewed from the stand and mounted to the wall. Button controls are located on the underside of the display and dual USB ports are conveniently located on the right side of the panel. The monitor’s back also has a hook to keep cables together and organized.
Key Features
  • Screen size- 24” Class Widescreen, 16:9 Aspect Ratio
  • Contrast Ratio- 80,000,000:1 (dynamic)
  • Brightness- 350 cd/m2 (typ)
  • 1920 x 1080 resolution @ up to 144Hz
  • 1ms response time
  • VGA, DVI-Dual Link, HDMI, Display Port, 4 USB 2.0 ports (includes 1 fast charger)
  • 7 different display modes
  • Sleek-design with tilt, pivot, and height adjustability
Price and Availability
The AOC G2460PQU is now available for $399.99 at national CE retailers. The display is backed by AOC’s three-year warranty as well as the EASE exchange program.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
