Monitors
AOC e2752Vh LED LCD Monitor
AOC announced the e2752Vh widescreen 27-inch LED-backlit LCD monitor, in which the company claims a 2ms response time and an unbelievable 20,000,000:1 dynamic contrast ratio. Ideal for multimedia applications, the energy efficient display also features two built-in 2.5 watt speakers for SRS-quality sound and is perfectly suited for PC gaming and Home Theater environments.
The e2752Vh is able to display 16.7 million colors and provides crisp, clear images even in fast action sequences and depth and detail in darker scenes. Its built-in speakers provide improved desktop sound. The versatile monitor is VESA 100mm wall mount compliant, meaning that it can be used on a desktop or conveniently mounted on the wall to save space.
The monitor's slim and streamlined appearance is complemented by ergonomic, user-friendly design. The e2752Vh includes easily accessible digital and power connections that are rear-facing for direct insertion, a placement that is much more convenient than the more common downward-pointing ports. The monitor settings can be adjusted via the on-screen menu system, which is available in 14 languages including English, French and Spanish. The iMenu option also allows the user to change settings using only the keyboard and mouse, so that it is not necessary to reach up to the screen to adjust contrast, brightness and other preset modes. Other bonus features include embedded Screen+ software that divides the screen into four self-contained work areas for improved productivity, and an Off Timer that sets an alarm clock to turn off the monitor automatically.
The ENERGY STAR-compliant e2752Vh also reduces energy costs and environmental impact. The display's LED backlight is completely free of toxic Mercury, and the monitor also includes an eSaver feature that lets the user preset power conservation modes for the display when the PC is not in use. The monitor's Power Saving Mode uses 50 percent less power, and Standby Mode uses only 0.1w.
Specifications
  • 27″ viewable image size, diagonal
  • 20,000,000:1 Dynamic Contrast Ratio
  • 2ms GTG response time
  • 16:9 Aspect ratio
  • 300 cd/m2 typical brightness
  • 1920×1080@60Hz resolution
  • DVI-D with HDCP, HDMI with HDCP digital inputs
  • Built-in speakers: 5 Watts
  • Windows 7 compatible
Price and Availability
The AOC e2752Vh will be available for $299.99 in April 2012 at national retailers.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
