Monitors
AOC E1659FWU 16-inch Portable USB Monitor
AOC E1659FWU USB Monitor
AOC has introduced an ultra-light USB-powered portable 16-inch LED monitor that receives both power and signal through a single USB 3.0 cable. The monitor (model E1659FWU) easily connects to laptop and desktop computers to provide a quick, simple solution for dual monitor setups. Using DisplayLink technology, the AOC 16-inch USB 3.0 Monitor provides portable convenience allowing users to benefit from a second display in the office or home, at meetings and in hotel rooms. One of the main benefits is that it does not require a power cord or VGA cable, making it easier to travel with.
Compatible with both Mac and PC, the USB 3.0 Monitor has a 15.6-inch viewing window that supports 1366×768 resolution at 60Hz. The slim piano black, highly portable monitor is almost 13mm thinner than the previous model and easily converts from landscape to portrait view using its secure, foldable metallic stand.  The E1659FWU comes with its own monitor carry case for complete flexibility when traveling and easily fits in most notebook bags.
AOC E1659FWU Monitor with laptop
In addition to being ideal for dual monitor setups on-the-go, the E1659FWU allows users to present easily in public meeting spots such as coffee shops by extending a smaller laptop’s screen onto the 15.6” display, eliminating the need to gather around one screen. The monitor can also be used for digital photo frame applications.
Every AOC monitor is manufactured to meet the most stringent green standards. Along with being mercury free, AOC’s industry-leading LED display technology allows for a powerful and crystal clear display while minimizing energy consumption.
AOC E1659FWU USB Monitor Back Views
Specifications
  • 15.6” viewable image size, diagonal
  • Brightness: 200 cd/m² (typical)
  • Contrast ratio: 500:1 (static)
  • Response Time: 5ms
  • Max. Resolution: 1366×768 @60Hz
  • Input Signal: USB 3.0
  • Colors: 16.7M
  • Power Consumption: 7 Watts (Max.)
  • VESA 75mm wall mount compliant
  • Plug & Play: PC/MAC compatible (Software included)
  • Special Features:
    • USB 3.0 Powered,
    • Energy Star
    • EPEAT certified
    • Carrying case included
Price and Availability
The AOC E1659FWU monitor will be available August 5, 2013 for $129.99 at Amazon.com.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
