Monitors
AOC e1649fwu Portable USB LCD Monitor
AOC announced the 15.6-inch e1649fwu portable USB 2.0 LCD monitor for business presentations or other multi-screen applications like social media monitoring, photo editing, expanded spreadsheets and more.
The AOC e1649fwu monitor offers a maximum resolution of 1366 x 768 at 60 Hz, and receives both its power and video signal through a USB 2.0 port. Designed to increase productivity for laptop and netbook users at home, at the office, and on the road, it draws a maximum of eight watts yet delivers brilliant clarity. The USB monitor has a built-in stand that supports both horizontal and vertical positions.
“AOC has leveraged DisplayLink’s USB 2.0 virtual graphics and the capabilities of our DL-125 chip to deliver a portable, extended monitor that requires nothing more than plugging in a USB cable, at a very attractive price point,” said Dennis Crespo, DisplayLink executive vice president of marketing and business development.
The combination of AOC’s e1649fwu and DisplayLink technology easily integrates with existing desktop / notebook environments and is supported on all leading operating systems including Windows XP / Vista / Windows 7 & Apple MAC OSX Tiger / Leopard and Lion. Linux support is also available through many of the standard distributions.
Price and Available
The AOC e1649fwu USB monitor is available now for $139.
Specifications
Cabinet Color Piano-black Glossy Bezel, and Back Cover
Panel TFT Active Matrix LCD, WLED Backlight
16″ Class, Widescreen 16:9 Aspect Ratio
15.6″ Viewable Image Size, Diagonal
Pixel Pitch 0.252 x 0.252mm
Display Area 344.2mm x 193.5mm
Brightness 200 cd/m2 (typ)
Contrast Ratio 500:1 (static)
Response Time 16ms (typical)
Viewing Angle Horizontal: 90 Degrees (CR>10)
Vertical: 50 Degrees (CR>10)
Scanning Frequency Horizontal: 30K ~ 60KHz
Vertical: 30 ~ 50 Hz
Pixel Frequency 85MHz
Maximum Resolution 1366×768@60Hz
Recommended Resolution 1366×768@60Hz
Supported Resolutions 640×480@60 Hz, 1366×768@60Hz
Color 262K
Video Input (Digital) USB 2.0
Connectors USB 2.0
Power Source USB powered
Plug and Play PC/MAC (Software Included)
Power Consumption 8 Watts ( Max. )
Dimensions (WxHxD mm) 376x236x35.5
Weight 2.3 lbs (1.06 kgs)
UPC Code 685417037483
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
