Monitors
AOC e1649fwu 16-inch Portable USB LED LCD Monitor
AOC announced the e1649fwu 16-inch Portable USB Monitor which features a convenient built-in USB port that receives both power and signal via a single USB cable for plug-and-play connection. The monitor does not require a power cord or VGA cable, and is ideal for dual- and multi-monitor setups. Along with functioning as an extended display, the accessory can also be used for on-the-go presentations.
AOC claims 50,000,00:1 Dynamic Contrast Ratio, 5ms response time and 1366 x 786 resolution. A handy built-in Smart Stand pivots out when needed and stores flush against the back of the monitor when not in use. The foldable stand supports both portrait and landscape display. Because the monitor does not require a power cord or VGA cable, it permits maximum portability while still allowing the display of multiple applications like instant messenger, movie player, gaming and digital picture frame apps.
The e1649fwu has a clean and modern aesthetic that is complemented by a black piano-polish finish on the bezel, while a hard glass screen offers superior protection. One laptop can support multiple USB Monitor connections to create a multi-monitor setup. The USB Monitor is also compatible with desktop PCs.
Every AOC monitor is manufactured to meet the most stringent green standards. Along with being mercury free, the packaging for the eco-friendly USB Monitor is made from recycled materials. In addition, AOC’s industry-leading LED display technology allows for a powerful and crystal clear display while minimizing power consumption.
Features
  • Panel Type: LED
  • Widescreen: 16:9
  • Screen Size: 15.6″
  • Viewable Image Size: 395 mm
  • Brightness (typical): 250cd
  • Contrast ratio (typical): 50,000,000:1
  • Response Time: 5ms
  • Max. Resolution: 1366×768 @60Hz
  • Input Signal: 1 USB
  • HDCP Compatible: No
  • Special Features: USB Powered
Price and Availability
The AOC USB 16-inch Monitor (e1649fwu) will be available October 2011 for $139.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
