AOC just released a huge 35-inch curved gaming monitor (model C3583FQ) for $599. The display offers 2560 x 1080 HD resolution in a 21:9 aspect ratio for immersive games or movies without any black bars.
Although it is a 35-inch diagonal display, it actually measures a full 32-inches wide. The screen has a 4ms response time, 50M:1 contrast ratio (VA panel), 300 cd/m2 brightness and 178/178 viewing angles. In addition, a 4ms response time, 144Hz refresh rate, a 2000R curvature and AdaptiveSync technology make this monitor one of the most affordable ways to game on a curved monitor with a 144Hz gaming panel.
To envision the C3583FQ’s 2000R curvature, imagine making a circle of just C3583FQ monitors. The screens would be 6.5 feet away from a seat placed at the circle and the circle of monitors would have a diameter of 13 feet. Displays with 2000R when compared to displays with 4000R offer much more “curve”.
The AOC C3583FQ features two 5-watt speakers that surround you in all of your gaming adventures built into the back of the glossy display. The monitor also has a connectivity hub with two HDMI ports and two DisplayPorts, as well as DVI and VGA integrated into the base. As a result, there are no dangling cables to mess up the clean lines of the rear of the display for an overall look that’s clean and simple.
Price and Availability
The AOC C3583FQ is available now for $599.99 at Amazon.com.
Specifications
Cabinet Color | Black/Silver |
Panel | TFT Active Matrix LCD, LED Backlight VA panel, 2000R |
35″ Class, 21:9 Aspect Ratio 35″ Diagonal Viewable Area |
Brightness | 300 cd/m² (typical) |
Contrast Ratio | 50M:1 |
Response Time | 4 MS |
Viewing Angle | Horizontal: 178 Degrees (CR>10) |
Vertical: 178 Degrees (CR>10) | |
Scanning Frequency | Horizontal: 30KHz~99KHz |
Vertical: 50Hz~76Hz | |
Optimal Resolution | 2560x1080x60Hz |
Recommended Resolution | 1920×1080@60Hz |
Supported Resolutions | 640×480@60/67/72/75Hz
800×600@56/60/72/75Hz
1024×768@60/70/75Hz 1280×720@60Hz 1280×960@60Hz 1440×900@60Hz 1680×1050@60Hz 1920×1080@60hz |
Color Depth | 16.7M |
Input Signal | 1 x VGA, 1x DVI, 2xHDMI (2xMHL), 2xDP |
Adjustability | Tilt: -3.5°+1.5° to +21.5°+1.5° |
Power Source | Universal 110V~240V AC, 50/60Hz |
Power Consumption | Power On: 60W (typical), Standby: < 0.5W |
Regulations | CE ,FCC, cTUVus, RoHS, EPA Energy Star®, EPEAT, Windows 8/Windows 10 |
Special Features | Kensington Security Lock, Includes AOC’s e-Saver, Screen+ and iMenu software |
