Anthem Room Correction System Creates Ultimate Audio Sweet Spot
Anthem’s new Room Correction System for the Anthem Statement Digital Audio/Video Processors uses cutting-edge technology to optimize the speaker/room interface to achieve the “target response” in any listening room.
ONTARIO, CANADA — 2008 — Anthem, a division of Paradigm Electronics Inc., a leading manufacturer of high-end electronics for music and home theater, announces a new addition for the Anthem Statement D2 digital audio/video processor– the Anthem Room Correction System (Model ARC-1). This system will also be available as an add-on to any existing Anthem Statement D1 or D2 processors.
Even when speakers are properly spaced and positioned, the room still can have a dramatic impact on the speakers’ performance. Dead spots, archways, furniture placement, ceiling height and countless other factors can turn a room into an instrument itself, playing alongside musicians or movie scores with unwanted contributions of coloration and resonance. Anthem’s Room Correction technology compensates for these acoustic problem areas by automatically configuring each speaker’s tonal balance for optimized sound.
The process starts when a test signal is sent from the Statement processor to each connected speaker. The signal is played and then picked up by an individually calibrated microphone, which is placed in various listening positions. The system puts each speaker through a full frequency sweep to highlight the problem areas and determine the necessary adjustments. Configurations are saved and can be accessed accordingly, allowing the user to optimize the system for multiple configurations. The system is extremely precise because the connected PC’s 64-bit floating-point processor calculates the correction curves. Truly an audiophile solution, the Anthem Room Correction system is compatible with any incoming audio signal without reducing the bit rate.
Anthem’s Room Correction system is based on equalizer filter requirements created during the Athena Acoustic Research Project performed by Canada’s National Research Council (NRC). The goal of this study was to determine the correct in-room “target response” and then develop a system to adjust each speaker to achieve this in any given listening room. Based on this analysis and research, and with the computing power already in place courtesy of the Statement processors’ twin-DSP engine design, Paradigm and Anthem’s design team created the Anthem Room Correction system to identify those characteristics and enable the Statement processor to make the necessary adjustments to achieve the desired in-room acoustic result.
Features of the Anthem Room Correction technology include an intuitive set-up wizard for new users, choice of auto or user mode, an interface that displays measurements for advanced users, Infinite Impulse Response Filters to prevent delay that would affect lip-sync and video game play, and PC backup.
Some additional features of the Anthem Statement D2 that aren’t related to Anthem Room Correction are:
• Four HDMI Inputs — Allow for digital video, digital audio and multi-channel high-resolution audio;
• Video Transcoding — Allows S-Video and Component Video inputs to be digitally processed and enhanced and then routed through the Component Video and HDMI outputs;
• Leading-Edge Video Format Conversion — Utilizes Gennum VXP image processing with Anthem’s custom firmware, boasting fourth-generation broadcast-quality image processing algorithms for conversion of any SD or HD video standard to other video standards, up to a resolution of 1920 x 1080p;
• On-Screen Displays — Both the Setup Menu and the Status Update (which is superimposed onto the picture during normal use) are displayed on the Component Video and HDMI outputs, at any resolution up to 1080p, providing the first “true single-connection solution” to an HD projector/display;
• Macrovision Support — Allows VCR tapes to be processed and output through HDMI;
• Aspect Ratio Conversion — Allows Letter-box and Pillar-box addition or removal through various user settings;
• Zone 2 Component Video Output — Allows the second set of Component Video outputs to be used for HD video switching of sources for the second zone video;
• Advanced Hardware Framework — Allows much longer cables to be driven without degrading the signal, or losing it entirely, and provides support for ultra-high bandwidth 1080p/60 Hz;
The D2 with Anthem Room Correction has an MSRP of $7499. The ARC-1 system will also be available as an add-on for existing Statement processors, estimated price is $399. For more information on Anthem, please visit www.anthemav.com.
Anthem, part of Paradigm Electronics Inc, is a leading manufacturer of award-winning high-end electronics for music, home theater, and distributed sound systems, sold internationally under the brand names Anthem and Anthem Statement. Anthem products are used at all levels of music reproduction and allow you to virtually “be there” every time you listen to a favorite piece of recorded music or experience the excitement of surround-sound home theater. Headquarters are Mississauga, Canada.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
