Andover Audio SpinDeck Max Completes the Circle…For Now
Andover’s upgraded fully automatic turntable comes ready out of the box with a pre-mounted Ortofon OM10 cartridge.
Andover Audio SpinDeck Max Turntable Lifestyle
Andover Audio has not taken its foot off the gas for almost 18 months and the budget hi-fi brand has yet another new component to add to the lineup. Multiple members of the ecoustics team use an Andover Songbird Streamer and SpinBase Wireless Speaker System at home so we’re more than just a little familiar with the products.
The budget turntable category is very competitive and the entry-level Andover Audio SpinDeck faces a lot of competition from U-Turn Audio, Pro-Ject, Rega, Fluance, and Music Hall.
Andover Audio SpinDeck Max Turntable with SpinBase in Black
Andover Audio SpinDeck Max Turntable atop Spinbase
I’ve run multiple turntables through the SpinBase and with relatively good results. It is a solid option for a second system in an office, bedroom, or even home gym.
Andover understands that its customer base desires affordability, usability, and solid sound quality for the money.
$599 is not inexpensive considering the available alternatives, but Andover have decided to offer a second turntable option as part of its Spin Collection.
The SpinDeck MAX
With its fully automatic operation, flick the start/stop switch, and let SpinDeck MAX do the rest. The tonearm will automatically lift from its rest position and start playing at the beginning of the record; at the end, it will lift up automatically and return to rest again. The design also easily allows the user to change turntable speeds or raise the tonearm with damped action.
Ortofon OM10 Cartridge with Andover Audio SpinDeck Max Turntable
The highly respected Ortofon OM10 cartridge features an elliptical stylus and light 1.5g tracking force. The cartridge comes pre-mounted with all tonearm settings pre-set for optimum performance.
The belt drive system is based around a rubber-isolated, low-vibration DC motor with internal electronic servo regulation for accurate speed and inaudibly low Wow and Flutter.
The machined aluminum platter and tonearm are isolated from its dense MDF plinth by elastomeric cones to absorb vibration, and to assure stable playback, even on unstable surfaces.
The main chassis of the turntable is made from engineered particle board, which is sturdy yet lightweight. An ultra-quiet synchronous motor with a silicone belt is housed underneath the chassis that drives a low-resonance platter made from MDF.
Andover Audio SpinDeck Max Turntable White
The SpinDeck MAX is now shipping and is available in either black or white finish to seamlessly integrate with Andover’s Spin Collection and to match with other audio equipment. A separate phono preamp is required if you decide to use the SpinDeck MAX with something other than the SpinBase.
Price & Availability
Andover Audio SpinDeck Max is available direct for $599 at andoveraudio.com and from participating dealers. Also consider:
Main Features:
  • Fully Automatic Operation
  • Pre-Mounted Ortofon OM10 Cartridge
  • Low-Mass Tonearm with Precision Bearings
  • Pre-Set Counterweight
  • Acrylic Lid Included
  • Available in Black or White
  • Made in Germany
Specifications:
  • Nominal Speeds: 33.33 / 45 RPM
  • Wow and Flutter: <0.04% RMS
  • Signal to Noise: -65db Weighted
  • Signal Cable Capacitance: 160pF
  • Tonearm Effective Tonearm Length: 211mm
  • Tonearm Overhang: 19.5mm
  • Weight: 6kg/13lbs
  • Dimensions (W x H x D): 420 x 119 x 360 mm (16.5 x 4.7 x 14.1 in)
  • Power: 12V DC / 1.5W
  • Power Adapter: Suitable for USA/Canada
  • Frequency Range: 20-20,000Hz
  • Channel Separation: 22dB/1kHz
  • Output Voltage: 4.0mV
  • Recommended Load Impedance:  47kohms / 200-600pF – MM – Input
  • Compliance/Stylus Type: 20μm/mN / Elliptical
  • Recommended: Tracking Force:1.25 – 1.75 Grams
  • Weight: 5g
  • Replacement Stylus: OM10
Related reading: Andover Audio’s SpinDeck 2 Turntable Unveiled for $299
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
With updated styling and connectivity, the $349 Andover SpinBase 2 is a compact wireless speaker designed to sit under any turntable.
Share the love of music and movies with hi-fi audio and home theater gift ideas that are guaranteed to impress.
Starting at $449, Pro-Ject's T1 Evo Series turntables come in three variations with or without Bluetooth and a built-in preamp.
At $699, the Pro-Ject Debut EVO 2 turntable features a balanced output option, new aluminum platter and Pick It MM EVO cartridge.
At $399, the Andover Audio SpeakEasy 4 powered bookshelf speakers include wireless Bluetooth, HDMI-ARC and a built-in phono preamp.
