Andover Audio’s SpinDeck 2 Turntable Unveiled
Andover Audio’s SpinDeck 2 Turntable offers better functionality at the same affordable price.
Andover Audio SpinDeck 2 Turntable
Andover Audio has focused over the past 3 years on affordable vinyl playback solutions that make sense for music listeners looking for the easiest way to enjoy their growing record collections; products like the SpinBase Max, One E Turntable Music System, SpinDeck Max, and the new SpinStage MM/MC Phono Preamplifier that we just reviewed appeal to a wide range of consumers. Andover has announced the successor to its original SpinDeck — the SpinDeck 2 Turntable and there are some rather distinct changes from the original design.
Priced at $299, the SpinDeck 2 is designed to strike a balance between good performance and operational convenience at a modest price.
Andover Audio SpinDeck 2 Turntable with SpinBase Lifestyle White
Three updates that have been added to the SpinDeck 2 include:
  1. Electronic Speed Control – This allows users to easily change turntable speeds.
  2. Auto Tonearm lift and return with Auto-Off function – This means users don’t have to get up to lift the tonearm back to its arm rest once record side playback ends.
  3. Built-in Phono Preamp with Bypass – This feature makes it more convenient to connect the SpinDeck 2 to any audio system. If your audio system doesn’t have a dedicated phono input with ground connection, no problem, you can connect the SpinDeck 2 using just RCA audio line-in connections. However, if your audio system has a dedicated phono input with the ground, you can bypass the SpinDeck 2’s internal preamp and connect just like any other traditional turntable.
Tip: When using the SpinDeck 2 with the SpinBase, SpinBase MAX, SpinStage, or any audio system with a dedicated phono input, set the “Phono EQ” switch to the THRU position.
Andover Audio SpinDeck 2 Turntable Connections
Feature Summary
In addition to the Electronic Speed Control and Built-in Phono preamp, here are the other core features of the SpinDeck 2.
  • The SpinDeck 2 is a belt-drive turntable that is paired with a low-vibration DC motor with internal electronic servo regulation for accurate speed.
  • Anti-vibration soft rubber feet are also included for stability.
  • The SpinDeck 2 also comes with a pre-mounted Audio-Technica AT3600 cartridge with great performance out of the box, with minimal setup.
Tip: You can upgrade the cartridge if desired. The SpinDeck 2 has an adjustable counterweight and a standard 1/2-inch cartridge mount.
  • Adapter for 7”, 45 RPM singles
  • .5m Dual RCA signal cable with integral ground wire
  • Machined aluminum platter with damped silicone rubber mat.
  • Electronically stabilized DC motor.
  • 12V/1A, 100-240V AC power supply with international plug adapters.
Turntable Specifications
  • Nominal Speeds: 33.33 / 45 RPM +/-2%
  • Wow and Flutter: 0.20% (33 RPM); 0.20% (45 RPM)
  • Signal to Noise Ratio (SNR): -67dB A-Weighted
  • Effective Tonearm Length: 8.5”, (214.5mm)
  • Overhang: 22mm
  • Weight: 10 lbs/4.5 kg
  • Dimensions (W x H x D): 420 x 119 x 340 mm (16.5 x 4.7 x 13.4-inches)
  • Power consumption: 1.5w
  • Power adapter: Universal 100-240 VAC/50-60Hz
Audio-Technica AT3600 Phono Cartridge
Audio Technica AT3600 Cartridge Specifications
  • Frequency range: 20-20kHz
  • Channel separation: 24dB/1kHz
  • Channel Balance: 1.5dB
  • Output Voltage: 4.2mV @ 1kHz, 5cm/sec
  • Recommended Load Impedance: 47kohms/200-300pF – MM-input
  • Stylus Type: .0006” Conical bonded diamond
  • Recommended Tracking Force: 2.5 – 3.5 grams
  • Weight: 5.7g
  • Replacement Stylus: ATN3600L
Availability & Pricing
SpinDeck 2 is now available in black or white for $299 at Andover Audio or Amazon.com. A clear acrylic lid is also included.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
With updated styling and connectivity, the $349 Andover SpinBase 2 is a compact wireless speaker designed to sit under any turntable.
