Andover Audio Spinbase Speaker System for Turntables
Spinbase with turntable in white open
All-in-one speaker and base for record players
Spinbase is a $299 powered speaker system designed to sit under a turntable or record player. It provides vinyl enthusiasts a compact, high-quality audio solution without the fuss and space required by extra speakers.
“Spinbase was designed with today’s vinyl lover in mind. It packs room-filling sound, simple operation, and easy connectivity in a compact package that sits comfortably under your favorite turntable.”Bob Hazelwood, Andover Audio Chief Engineer
Spinbase Setup
Simple Setup
Spinbase removes the need for multiple cables and extra speakers, with a setup that can’t be easier:
  1. Place a Spinbase on any flat surface.
  2. Place your turntable or record player on top.
  3. Connect the audio cable from your turntable to Spinbase.
Minimalist Design
Spinbase is controlled via a single dial, which turns on the unit and allows for fine volume adjustment. A subtle indicator on the knob points to “off” or the current volume position, without interrupting the sleek look of the front. A metal perforated grill, lined with speaker fabric, allows for musical transparency, while providing a subtle, yet sophisticated look.
Eliminates Feedback
One of the main advantages to Spinbase comes from the “base” part of its name. The base itself is uniquely constructed with Isogroove™ technology to eliminate the age-old problem of acoustic feedback that’s caused when speaker vibrations reach the turntable.
“…spin your records and get satisfyingly smooth, feedback-free sound and musical pleasure well beyond the Spinbase’s $300 price point. I loved it!”Michael Fremer (Editor, Analogplanet.com)
270-degree Audio
The Spinbase audio system utilizes a clever arrangement of two woofers and two tweeters to produce an expansive stereo-image. Its clarity and output levels match the performance of small bookshelf speakers. Traditional turntable/speaker setups create “sweet spots”, which only provide one ideal listening location. Spinbase fills the room with a surprisingly balanced sound stage, making every location the best place to listen.
Spinbase Back Panel
Bonus Features
Built-in wireless Bluetooth and extra inputs ensure other audio devices aren’t left out. That means Spinbase also doubles as a Bluetooth speaker for streaming music, while its extra set of regular RCA inputs allow a stereo connection to any CD player. In total, Spinbase is actually a complete analog and digital entertainment system.
Spinbase with turntable in black
Key Specifications
Design
  • Available in White or Black
  • Large, Ergonomic Knob
  • Perf Metal Wrap-Around Grill
  • Vinyl-Laminated MDF Enclosure
  • Recessed Andover Logo
  • Internal Bracing for Rigidity
  • Dimensions: (18in/46cm W, 13.5in/34cm L, 3.25in/8cm H)
Audio System
  • Isogroove Acoustic Feedback Elimination Technology
  • Stereo Two-Way Vented Speaker System
  • 2 x Soft-Dome Tweeters
  • 2 x Active Woofers
  • 270º Sound Field
  • Class D Amplification
  • Low-Noise Circuitry
  • Bluetooth
Back Panel
  • Phono-In (for Magnetic Cartridges)
  • Line-In (for Ceramic Cartridges or an Auxiliary Source, such as a CD Player or Streaming Device)
  • 1/8″ (3.5mm) Headphone Output
  • Special EQ Switch for Ceramic Cartridge-Equipped Record Players
In The Box
  • 1 x Spinbase
  • 1 x Power Adapter (US Three-Prong Power Plug; Supports both 110v and 220v)
  • 1 x RCA Cable
  • 1 x Quick Start Guide
Price & Availability
The Andover Audio Spinbase is available now in black or white for $299 with 1-year warranty at AndoverAudio.com or AudioAdvice.com.
Need a turntable too? Andover is also reselling the T1 Turntable by Pro-Ject for $329, but word is a new turntable from Andover called Spindeck is coming mid-2020 (summer).
Update
The Andover Audio Spindeck Turntable was released on July 17, 2020.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
The 10 best digital music streamers of 2023 include models from $219 to $2,500.
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
