Anchor Bay Technologies Unveils DVDO iScan VP30 Video Processor Featuring HDMI Input/Output to 1080p
Campbell, CA — September 2005 — DVDO, powered by Anchor Bay Technologies, Inc. (ABT), announces the release of their next generation high-definition video scaling processor, the DVDO iScan VP30. This third generation 1080p capable video processor builds on the success of the iScan HD and iScan HD+ and is the first stand-alone high definition video processor offered by DVDO with four HDMI inputs.
ABT’s Precision Video Scaling II technology, which incorporates 10-bit scaling, enhanced sharpness controls and non-linear scaling, appears for the first time in the iScan VP30. Analog transcoding and analog HD processing allow connections to be “anything in, anything out” thereby reducing the amount of cables needed to connect all video sources, current and legacy, to a High Definition display. This affords the maximum connectivity options for consumers who wish to incorporate their legacy analog sources into a theater setup with new digital based receivers and displays. The iScan VP30 offers the greatest flexibility of any processor currently available by allowing the user to precisely match their display’s native resolution to any resolution between 480p and 1080p, including 720p or 1080i, and has many preset output resolutions for plasmas, LCD, DLP, LCOS and CRT-based displays.
The iScan VP30 features 11 video inputs: four HDMI, two Component, two S-Video, two Composite, and an RGBHV input along with an optional SD-SDI input. Each input has separate picture controls allowing the user to set their own parameters for each input to achieve the best picture from every source. Standard and custom aspect ratios can also be setup and then “one button selected” giving users many options for fitting and viewing an image on their display.
It also provides complete pan and zoom capability to position and/or stretch your image on the screen with overscan, underscan, and border controls to eliminate “black-bars” and fill the entire screen. The iScan VP30 also functions as an audio switcher and router, featuring four digital audio inputs and one analog that can be assigned to any of the video inputs to allow one button switching of both audio and video together. Each one of the audio inputs on the iScan VP30 employs ABT’s Precision A/V Lipsync which eliminates the annoying audio/video delay common on many displays. The four HDMI inputs accept both audio and video, allowing one simple connection for sources like a DVD player, high definition set top box, D-VHS, or the next generation game consoles.
Serving as a complete A/V hub, the iScan VP30 provides simultaneous audio/video switching with “any rez in — any rez out” video up-conversion and one simple wire to the display.
An elegant front panel designed to complement the most sophisticated home theater systems will allow the iScan VP30 to blend seamlessly with other components. For home theater systems that utilize an equipment rack, an optional rack-mount kit is available.
The iScan VP30 will be available for volume shipment to authorized DVDO Resellers in fall 2005 and will have a U.S. MSRP of $1,999.
For more information on DVDO, please visit www.dvdo.com.
Anchor Bay Technologies Inc. (ABT) designs, manufactures, and markets semiconductor and system-level solutions for the next generation of Digital Television and Digital Video electronic products. Headquartered in Campbell, California, ABT is the parent to DVDO Home Theater Products and the creator of the proprietary DVDO iScan line of video processing systems. Anchor Bay Technologies’ Precision Video Scaling technology is based on ABT’s proprietary video scaling engine that can independently scale an image horizontally and vertically to achieve an outstanding picture quality for today’s high resolution video displays.
Press Contact:
Caster Communications, Inc. at 401.792.7080
Joseph Hageman: jhageman@castercomm.com
Nicholas Brown: nbrown@castercomm.com
For digital images: www.castercomm.com
The DVDO and iScan trademarks are licensed exclusively to Anchor Bay Technologies Inc., and are registered trademarks of Silicon Image Inc. All products bearing the DVDO and iScan trademarks are based upon technologies, architectures, and product designs originally created and developed by the ABT Team. Powered by ABT is a trademark of Anchor Bay Technologies.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
